Check it out, this article taken from Performance Forums... (thanks Troy, the man in Itami for this one!)
Theres nothing really new to said here, although you can see from what Ghosn says, he's got a stranglehold of the GT-R development program, and it seems as though Ghosn wants to have his name printed somewhere on the bootlid maybe...
https://www.sau.com.au/forums/topic/31079-v35-based-gt-r-news/
Ghosn's not the most popular guy in Japan now is he?!?! lol...
"The man who canned Godzilla" was one story I read when he innitially said that there was no place for a straight-6 AWD supercar in todays market.
Bastard!
Adrian
so are they still making the R34's till 2007 ? or have they stoped production ?
I pretty sure they stopped a making them a year or two ago along with the S15. The last R34's made were the Nur spec GTR's. They didnt meet the new emission laws that were introduced into Japan or something like that.
Anyone else confirm this??
Cheers
so we're going to have pointless articles not stating much like this for another 3 years :(
i just wanna see the final version damnit :( damn Ghosn !!! damn you to hell!!
what else is going to be popping up in the meantime though? any other interesting developments in the nissan stable//?
Guest INASNT
Cheers
The crap about the Rb26dett and Sr20det not being able to meet the new emission laws is total crap. If Holden and GM can make their pushrod petrol buring dinosaur engines meet the new emission laws then so could nissan easily.
Its all comes down to Nissan being owned by renault and the main bosses at renault not wanting anymore inline 6 or 4 cyclinder turbos in production.
Thats true and not true
Toyota isnt owned by Renault and they are not making 1JZ / 2JZ any more. Japans emissions laws became alot tougher in 2002.
sorry to go off topic but, can someone explain to me why the GTR model is an R35 whereas the non GTR models are V35s ? All previous non GTRs are still r3#s.
because the new skylines are powered by the vq series engine. hence v35
rb engines in the previous models made them r3- (asides from r30)
next gtr will be kept r35 to keep the tradition ive been led to believe.
NEEEEEXT!? Ah, hi there rrrage...:(
Could I answer your question with a question?:(
Ah-hem...:) Who said the Next GT-R is designated "R35"?
Fffffffwhat I think you'll find is that the new GT-R will pipple-o-popple-lopously be based on the "V"35 platform... without question. It WILL be a "xx-V35 GT-R".
All this "R35" business is sprouting from pre-2001 Tokyo Motor Show rumours about the current Skyline... even some Japanese guys were saying "R35". But now they've all changed their tune.
Right... NEEEEEEXT!:( j/k
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
