  • Replies 199
To all those who were thinking of coming today is the last day to put the payments into club acc. 27/05/10
Any further additions to the list must be via ph or msg call to toddlls on 0438349071, tell me who you are & ur user name or otherwise you will not run.
Thanks to all who have paid, am looking forward to seeing you all there
Todd
if your name is not on the list or has paid not beside it call me on the number in the post be4 this one -immediately, I WILL BE PRINTING THIS LIST 2MORROW MORNING & IF YOUR NAME AINT ON IT WELL YOU KNOW WHAT WILL HAPPEN?????
Todd
Todd
Hi
You have me on the list twice
Numbers 12 and 37
All paid 5-6 weeks ago
Cheers
I cant make it tomorrow. So my spot is free if someone wants it or if Noel hasnt already organised somebody else to replace me.
My car isnt finished and I cant take the race car! :)
I'm sorry to hear that mate, it would have been awesome to have you along.
considering how hard it rained over night and the weather is set in now...
id have a fair stab in the dark that today will be canceled?
track cam is not working but it is raining out there im told...
we might get lucky if the sun pops its head out by 10-11am or so...
let us know todd...
let us know todd...
in the last hour they have had only about 1mm, hopefully that stops and we are good to go! I will keep an eye on the alert station that work has out there though and let every one know how its traveling
I have just spoken to Willowbank- THE EVENT IS POSTPONED DUE TO RAIN, I repeat--EVENT IS POSTPONED DUE TO RAIN.
The drag strip & facilities are extremely wet & Willowbank staff think this is too dangerous to risk The Vehicles, Drivers & Track.
Full update about alternative date will be announced ASAP.
I appreciate your patience & apologise for our weather.
Todd
Yeh I was keen to run. Guess it will have to be next time!
There is hope for yah, we will run another asap that hopefully fits in a lil beta for everyone
its raining in redbank at the moment. I know thats still a fair distance away from willowbank. so depends whats happenin out there.
Was looking forward today.
hope that it will clear up.
Facilities are extremely wet, they are considering cancelling tonights due to how wet it is there also
I hope it does clear
I was looking forward to coming out and meeting everyone.
We will sort out a replacement day asap, I would like to see you guys up against some of our finest also
Todd
Yeah Col, it is just too wet out there according to staff at the track, alot of water has fallen & they are worried as to whether the track will dry out enough for us to run safely as there is run off water coming into staging lanes & pit area is soaked.
I called at 8am, 9am & again at 10am with the final call being made at 10.
The staff at Willowbank said I could have called at 8am but I tried to hold it off as long as I could & asked if we could make the final call at 10am, which they agreed.
In the interests of safety is the reason why we finally did call it off. I dont ever want a high speed crash by another due to my inadequacy to do the safe & right thing when I should have on my conscience.
We all love our cars & love our Events more but the Events wont happen unless we have the cars & we wont have the cars if they all get wrecked at a wet track.
Hope this is understood by all.
We will run again as soon as we can get the replacement date sorted.
Todd
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
