BN/Uras/Whetverthefuck on sedan... done right:
you're incorrect :P
hey I have a set of genuine LM's for sale. Champs too, only $5000. Red centres and all.
this is like one of those movies where it starts good, gets great, becomes unbelievable and then just goes to shit
that kits wrong
too big for the car
Edited by Mohsen
