BN/Uras/Whetverthefuck on sedan... done right:
you're incorrect :P
hey I have a set of genuine LM's for sale. Champs too, only $5000. Red centres and all.
this is like one of those movies where it starts good, gets great, becomes unbelievable and then just goes to shit
that kits wrong
too big for the car
Edited by Mohsen
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
