Up for auction tomorrow is a 2004 PNM35 with 43,000kms, 3.5L na in Manual. Very hard to find in this form. I wonder how much she will go for? Who wants a guesstimate?
She is starting at 1,150,000 yen.
http://ayp3.nihoncars.com/cars/37128083/0/...%3Fyn3O6yyn.jpg
http://ayp3.nihoncars.com/cars/37128083/0/...Fyn3O6yy%3F.jpg
http://ayp3.nihoncars.com/cars/37128083/0/...%3Fyn3O63y3.jpg
https://www.sau.com.au/forums/topic/311057-whos-after-an-m35-axis-in/
weird, it doesnt have the later model front end like a PM35 SHOULD have.................
good pick up Iain,,, It has the Pokemon eye's........
That dash does not look quite right for a PM35 either.......
This subject was brought up a few months back regarding a manual M35 3.5 n/a version hitting our shores. I am converting my C34 to manual after my kit goes on, relatively simple. After reading further of the hassles with the bellhousing and other complications my mind was made up.
Now im more interested in M35s. And Volvo 850R T-5R wagons, lol. :)
Edited by dirtyRS4
And what's that giant clitoris where the screen is normally positioned? haha
LMAO... Perfect description.
Maybe some kind of bracket for a screen? There is some cable hanging there also..
of course its supposed to be there, where else is it supposed to go?? it COULD be a G35 console and thats why the handbrake is over that side. i havent seen inside enough V35 manuals to see if the handbrake is on the right or left.
on autos there is a 3rd pedal that does the hand brake's job
It looks like a transplant from the V35. And yes that is the standard location for the handbrake.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
