Hey guys ive recently noticed that right under where i sit in the drivers seat, whenever in gear (manual transmission) and in hi revs (i.e. 4000rpm +) my car has this really loud sucking noise.. or as if thers a massive hole in the exhaus system and air is jus gushing out of it...
it has lost top end power as well... i got a new cat fitted today - didnt fix the problem - i can still hear it occassionally... and the guys had it on the hoist and listened through a stethoscope (sp) on every joint, gasket and bit of exhaust and couldnt find any faults... before and after the cat being fitted..
just wondering what this could be?? im under the impression the stock extractors wouldnt have anything wrong with them.. they generally dont get holes in them do they?? that is one thing they couldnt check at the time because stuff was in the road so i just said dont worry about it...
anyway if anyone has a solution/suggestion would be much appreciated!
Cheers
https://www.sau.com.au/forums/topic/311154-sucking-air/
The exhaust runs underneath the passenger side of the car and for the record if you had an exhaust leak you should be able to smell it under the car, other thing is to check to see if your extractors are cracked etc. Try checking your air intake aswell.
https://www.sau.com.au/forums/topic/311154-sucking-air/#findComment-5123140
umm yeah well when i first took it to the exhaust shop to get it all looked at.. there was black residue all around the connection of the cat etc but it didnt seem to be making any noise from that section at all when he put the stethoscope to it...
but then i got a hi-flow cat in that same day so everything was taken off and tightened again so im pretty sure it isnt the flange or around the cat area... and it was done at a reputable exhaust shop with a high rep.
and nah i havent looked for holes in the floor.. but i will do never thought of that since i did get it converted to a manual a month or so ago and some modifications were done to fit my clutch pedal, i believe its only started doing it after all this work was done...
but anyway.. its going down this arvo to get looked at hopefully and i'll get all of these things checked out but yeah im still leanin toward my extractors now... i have been wanting a set from DKNE so maybe here's my excuse :)
cheers
Edited by noely1
https://www.sau.com.au/forums/topic/311154-sucking-air/#findComment-5126220
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
