Hi guys,
I'm a new member to this forum. So I still have a lot to learn....?????
Anyway with all these talks about finding and owning a GTR. I was just wondering anyone could give me some hints on their occupations, as with my current job I won't be able to own one until I'm 50. By then I will look like a try hard.
Cheers,
https://www.sau.com.au/forums/topic/31121-whats-one-have-to-do-a-own-a-gtr-r33/
  • Replies 73
I plan to win lotto and buy this hell nice R34 GTR i've seen at a shop in sydney... :( that's the easiest way to do it... i just keep forgetting to buy lotto tickets... lol
i see a lot of drug dealers with nice cars... lol.... hmmm other than that, no idea... lol
I can only concur with Leewah, work hard and save. If price is the motivating factor, go for an R32, they'll set you back around 20-25K (anybody feel free to correct me here). Otherwise if you want an R34, start saving your pennies, and open a managed investment account, stockmarket's gonna give good returns this year :P (just some friendly unsolicited financial advice... geez, my degree does come in handy!)
If you have been working for 6mths or more fulltime than almost any bank these days will give you $25k without too much of a struggle. Then you only need to save another $15k and your home!
Of course, I wouldn't recommend this but hey it will work if you -really- want to get a GTR (and pay $60k for it instead of $40k for it :P)
Argh, argh aaaaarrrggghhh car loans!!!!! Sorry, just had to say that, but those things are evil just like credit cards. :P
I've been there, it's a much better feeling when you own it outright. There's no struggling to make payments, especially with 25K, it'd be at a fair rate of interest too, probably twice that of a house loan.
Does anybody know if they let you mod the car if it's under finance?
Best thing to do is start with something a little more realistic, IE a r33 GTSt.
My plan is spend some money on my GTSt, that way i learn the car/engine etc and get myself a good base of preferred Panel/Paint and Mechanical places.
Then sell the Gtst for around 20K, Goto the bank, show them i have a 20K deposit for it already, borrow 20K easily and pay it off in 1-2 years.
Going from basically nothing to a GTR is not a good idea.
They are very dangerous cars in the wrong hands.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
