Hey guys, my mate gave me a lil led display that you wire up as an air/fuel ratio display....
The wires are:
positive, negative and O2 sensor.... Ok, so the first 2 are a piece of piss....
actually, should i wire the positive throu accessories (cigi-lighter cable) or straight to battery? or other?....
now, the question i an totally stuffed on.... the O2 wire.... where and how???
all help appreciated... diagrams are excellent....
cheers.
Dave.
https://www.sau.com.au/forums/topic/31123-wiring-up-air-fuel-ratio-leds/
From memory, you need to tap into the white wire off the O2 sensor. Check it with a multimeter - output should vary between 0 - 1V.
Hook the power off the ON posi - ie only supply power while the engine is running.
Ok, i know the sensor your talking about now.... might be fun to get to... lol....
blind_elk: when you say to hook the power off the On posi (i'm guessing the ignition switch)... how do i get in there (neva been there on this car)... just take the steering casing off? which wire? (colours etc)...
thanks again.
Just need to find something that only works while the engine is running - maybe something like the wipers (I can't remember how I did mine).
It's not so hard to splice into the wire at the sensor, but you could alternatively pick up pin 29 at the ECU.
Ok, so i'm guessing i'll be taking out the floor in the passenger foot well and looking for that wire then?...
then what would you suggest i spliced the +ve wire into? If i connect it to the ciggi lighter will it work without a switch?.... I've only ever hooked the neons up through that wire.....
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
