Hey,
I was cleaning my AFM today when i noticed there was a plug/socket (grey plug with no wires attached to a small black box) on the top of the engine, just near the intake plenum which looked a bit odd because there was nothing plugged into it.
so i googled a few pictures of rb25det's and they all seem to have something plugged into it.
here is a picture of what mine looks like,
and here is one that I googled looks like,
Also how much should the stock boost gauge read on a manual r33 with a blitz catback.
Any help would be appreciated, thanks.
Cheers,
Scott
Edited by scotty_1989
https://www.sau.com.au/forums/topic/311244-help-r33-gtst-question/
the good news is you do have the plug....its only the wiring to the plug that is missing!
no idea what it is, its plugged into the throttle body but it can't be the throttle position sensor unless your car runs horribly or not at all
its the throttle valve switch connector/sensor (Automatics)
page EN-68 in the R33 workshop manual
normal boost should be about 5ish psi with a catback (somewhere in between -7 and 0 on the factory gauge)
Edited by BstewyR33
cheers heaps guys I just bought the car a few days ago and was stressing a little haha..... When i hit boost the factory guage boosts to about the half way line between 0 and +7 on the gauge, is that correct? Also why do you recomend mod wise first, bigger fmic or full turbo back exhaust?
Cheers again
if you've got the stock air box, get yourself a decent panel filter or go get a decnt pod filter (if you want to go down that path), 3 inch exhaust turbo back (or keep your catback) up to you, then you can start thinking about a front mount
cheers for the advice, i have a pod filter on the way, got an apexi power intake, so ill install it as soon as it arrives......As for the next step, wasnt sure whether to go turbo back exhaust or fmic, you recomend exhaust first though yes?
cheers
cheers
personally i'd go exhaust 1st (with a highflow cat), as the above fella said, thats just my opinion haha, my reasoning is, why upgrade your cooler to a front mount if you havent got the exhaust to capture the extra gasses. (note: there wont be a massive amount more, however every little bit of exhaust scavenging won't hurt)
that would hopefully stop all the popping sound from an exhaust if its just cat back.
then get your cooler. :(
just my advice
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
