AFAIK the system is based on the number of years the emperor has been on the thrown. The current emperor's reign is called Hesei (or something like that!) and so you see years written as H7 or H11. This year (2004) is H16 i.e 16 years since he became the emperor. The previous emperors reign was called "Showa" so you get S46 etc.
Hope it helps!
Dave
so
2004 = H16
2003 = H15
2002 = H14
2001 = H13
2000 = H12
1999 = H11
1998 = H10
1997 = H9
1996 = H8
1995 = H6
1994 = H5
1993 = H4
1992 = H3
1991 = H2
1990 = H1
1989 = S?? !!
I think Showa went to 52 or something like that, maybe Rezz or Dai Oni know more!
Dave
You forgot H7
Interesting fact about this:
THE EMPEROR TODAY: The reigning Emperor, Akihito is number 125. The first was, Jimmu (660-585 B.C.).
Akihito's reign is called Heisei, meaning ("the achievement of complete peace on earth and in the heavens"). Because of the pervasive influence of the Emperor on Japanese life, the adoption of this name for Akihito's reign can be expected to influence Japan's policy. Students of Christian end-times prophecy might also take note, given Japan's use of the United Nations to achieve policy aims. Akihito's slogan could be interpreted as referring to the long period of peace and prosperity predicted in Christian theology, a period that must precede great changes prior to the return of Jesus Christ.
So the H is taken from what they call this emporers reign and not his name :D
I have seen dates written as such:
1 / 10 / H3
1st October 1991 etc.
I wouldn't be suprised if that was January 10th 1991...
The Japs copy the Yanks sometimes with the month/day/year bizzo.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
