Best time to go is mid morning to mid afternoon.
In the morning, people seem to be warming up and not going that hard. After the track starts to warm up a bit, people start to put down their fast laps. I haven't really hung out till they finish in the afternoon, my tyres are normally gone by then :P.
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5128758
Wooohoooo bout time we got you out there.
I will be there with the open wheeler and Rebecca is running the GTST. Mark wont be running, but he'll be jealous now.
There is a BBQ running most of the day and cold drinks all day.
Who is going to do the video? I've got the camera.
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5128761
did you email your paperwork/entry form to Barbara?
Yeah, got a email from James this morning. :P
P.s. Grumblebee looks likes this now cept with better matching wheels and a couple of stickers
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5129284
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
