Ok, so heres the idea:
Replace the orange indicator lenses on the front bar of the S2 with clear lenses and put in silver coated globes that still flash orange.
I've called Nissan and been told that the you cannot buy the lenses alone, you need to purchase the entire assembly which costs $815.75. Apparently the lenses are fixed in to the assembly (can anyone else confirm this?)
Any suggestions? (Apart from going and stealing some)
Jason.
I'm just surprised that Nissan don't offer a replacement lense, bearing in mind the closeness of the lense to the ground and the fact that it could smash/crack quite easily from rocks/stones on the road.
I guess they were thinking they could make a lot of money from it?
Oh well, I'll keep looking and see if I can find a smashed one (hope I can't though :P).
Thanks,
Jason.
I haven't seen anyone thats done it, but thought it might make mine stick out a little more. Just a tad different to the rest.
I'm also contemplating removing the stove top red lense (SHOCK HORROR GASP) out of the back and putting in some red silver coated globes (if they exist) just to see what it looks like. Only problem is they don't seal correctly apparently and I'd have to use some silicone seal or something and if I didn't like it, I'd have to buy new rear lights.
I'll let you know how it goes if I get to do it.
I'm going to use my uber-elite google skills tonight to see what I can find.
Jason.
y0, alex.
Last I heard was that the pictures were fake and were just a photoshop jobby.
Clearcorners.com mention that they are looking at making some, but there's f u c k a l l information on their site.
I'm not too fussed about the ass end, but I just really want to do this clear indicator to the front bar damnit.
I figure that the driving/fog light should be pulled out and replaced with a super bright cow fried in the headlights type driving light and then the lens should be moved across to the indicator
problem solver and the car can now stun a cat before running it over
hey jason did nissan mention that its $815 a side not the whole set. kekeke
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
