Hi All,
Just looking for some help - engine is an RB25DET Series II...
I noticed tonight that when I open the throttle I get a click like a blown fuse from this thing...
Problem is I don't know what it is or what it does. It is situated at the front of the engine on the intake side right next to the thermostat.
Hoping you can shed some light here are the pics: Anybody know about it?
Thanks,
https://www.sau.com.au/forums/topic/311567-help-with-part-identification/
Or I could have been wondering why there was a plug that was not connected and why the car was not feeling normal.... Its pretty damn obvious when your under the bonnet and pull the throttle cable...
Got news for you lachlnw - this is a forum - believe it or not people use it to learn, others not naming names use it to express to the rest of us how much of a knob they are
I'll let the people decide which category you fall into.
jesus christ you need to get a girl friend . or a new one that you dont avoid enough to find stuff like this . seriously what were you trying to do when you discovered this?
Young people of today :laugh:
I Guess then, if youd mentioned the plug wasnt connected and the car wasnt running right in the OP, then people wouldnt have jumped on you about not worrying about it :worship:
Dont worry though, SAU is well known for the veteran members flaming the crap out of people all the time, you arent the 1st and wont be the last!
Just Chin up and ignore it. :(
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
