  • Replies 50
Using Tapatalk is retarded, why on earth would we willingly give free tonnes of very viable content to that some company in Hong Kong, so that they can make revenue from app sales? at least if it was a free service for end users I can see the point in supporting them.
  • 4 months later...
I've been using the forum on my iPhone since it came out and the same with the iPad... ...I'm doing it right now even... ...there is no need make any changes for the iPad, unless it comes to the resizing of the reply windows... ...if you type more than what the space has it becomes hard to read back what you've typed... ...on the iPhone it is even harder... ...but the new iPhone 4 is so much better for reading on...
Yeah i discovered minor problems with the site on my iPhone. There not much but would be handy to have a mobile version/app
The problems I've found so far are:
posting a new topic, You cant type in the box where you want to write all the info for your topic (The title can be written in however)
Replying to PM's (maybe even creating new ones?) it wont let you type in the box where you write everything for some reason
I think also replying to topics if you dont use fast reply you are unable to type as well
Apart from that the site runs pretty well on safari
  • 2 months later...
Sau iPhone app for the latest upgrade 3.0 isn't anything like the one I use on the net.. The site Is heaps better on the computer, when i log on my iphone its shit, hard to use, only get to choose from the list of forum topics, no cp, no homepage/profile, no search button, not alot really when will this get upgraded? When the site is back to normal?
I hope so :)
Anyone else got this problem on their iPhone?
I hope so :)
IP Board app is just a portal app for the mobile version of the forums. It's just a matter of clicking "full version" at the bottom of the mobile page.
Wow that just made me look stupid haha.. Did not see that there aye.
Thanks heaps mate
Much better :)
Not a problem...
We all have stupid moments every now and then. Saturday night I droped a stubby down ten steps without it breaking. Then in front if about 100 people I picked it up and opened it without thinking. Lots of lol-ing was had by everyone.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
