  • Replies 67
  • 3 weeks later...
hei mate, can u please give me the dimension and weight of the dump front pipe? need to check the postage cost before any further negotiation
usually for this kind of stuff, postage is a biach!
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Hey Buddy, where did u get the 100k service kit from and does it include everything needed for the 100k service for a R34 GTT?? Could you even post a pic of the 100k service kit..
Still have thebdump pipe? Whats the sizing
3 inch mate
got it from elite racing, got all you need for the 100k motor service
Edited by nsm034
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
