MATE! Whats your problem!!!....do you have a problem...me think's so.......I had a simple request your simple mind could not decipher! :)
I don't use PC(because I hate Microsoft OS's)....therefore I cannot use FAST.
And no I don't no my VIN# off the top of my head.....maybe I should....hey look if it really makes you happy I'll get it tattooed onto my arm.
P.S. sorry....i'll stop the highjack now!
Bootcamp with windows 7!! its just the same as osx.. just a little different :D
He said he has suade seats no? isnt that pm35?
Bootcamp with windows 7!! its just the same as osx.. just a little different :ermm:
If only it was that easy :) Windows 7 Ultimate is running fine on my macbook pro but not on my 27" i5 imac :P Hopefully apple will release another bootcamp update soon!
so why are mac users running windows instead of osx?? :)
Because once in a blue moon you will need to run an application that is only available on winblowz.
I pretty much use OS X all of the time, just depends what type of applications you need. :)
LOL.....good one Iain :)
But having Windows on your MAC is sort of like having that neighbour next door that you cannot stand but have to get along with.....you only visit when you have to other than that they can go get f$#ked. :)
Edited by Jetwreck
  • 5 months later...
i'd have to agree with you andy, mine came with the autech bodykit, wheels, satnav, leather as well as suspension and brake upgrades.
can you explain what the axis autech suspension and brake upgrades are please?
I have the 2002 M35 axis autech ,is that applicable?
Edited by samuri
brakes are standard, suspension is revised springs and shocks
disregaurd previous comment.. i cant edit it!
LOL
You should be able to edit up to a couple of minutes after posting... and yes, Fast is around 1.5GB
What does revised springs and shocks mean? Revised to what?
Thanks
Slightly different spring and damper rates to the standard RS and RX suspension (same ride height though).
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
