  • Replies 44
I cant believe i didnt see this this thread till now, im shattered haha
we should organise an ongoing get together for just stag owners!!!!
what do you reckon.... oh im peter by the way and sorry i didnt make it tonight, i missed this thread and the stags on jacks in the garage...
Nice to meet you all, it was a much better turnout than I expected. What was the count? 8 Stags in the end?
I think it was 7 all up, yeah? (unless I missed one :) )
Nice to meet you all guys (where was the puppy Shan?)
Maybe find a nice driving road to use next time and bring a suitable camera :D
Pics no good Cam?
Next time ill bring my helmet cam which i can mount on the roof and get some video if we go for a drive.
Lol, I remember seeing a Volvo with the whole family inside wearing stackhats, you just reminded me of it. :blink:
hi guys, i just bought a Stagea is 99model, will pick up the car next week. I wish we can have another stagea meeting soon. I didn't see many stagea around in my area. I from sunshine Melbourne, anyone from there?
get a damn good alarm on your car ;)
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
