I am looking into replacing stereo in m35 stagea as factory cd player doesnt work. Chris was good enough to let me know that they are repairable but for $600. I would still have to remove it as i live south of sydney so driving it up to Brisbane for a install is a bit silly. was also toying with the idea of an after market head unit, but have been told the facia plates are $500 because they include some air conditioning module as it has to be broken off in the removal process which doesnt sound right to me. any help or a step by step diss-assembly guide would be much appreciated.
https://www.sau.com.au/forums/topic/312147-m35-stereo-install/
Here you go...
Here
I think lots of us have the stuff autochanger... It is partly caused by the heads not being "parked" (like on an old hard disc) before the cars are transported to Oz.
Because it is such a pain to get fixed, the iPod install really does seem to be the best solution..
Using one of these...
iPod controller
panel and AC controller are the go to do it correctly. the A/C side of things is PART of the radio panel and as such it's not a moddable (new word -yay!) item. I can take photos (and have done so in the past.) but the question will still come up and I'l still answer it the same way :cool:
as for the parking issue - nup! these things spit gears due to age and heat. common ones are on the laser drive and as such it causes a chain reactiion taking everything in the direct path with it.
doing it cheaply, $320 + frieght will net the IPOD lead from me and you can tear the dash down in 20 or so minutes plug it in and you are done. if you have the controls on the wheel then the ipod will drive from there as well.
your call.
this sounds great, but the pulling down of the dash is what im concerned about.
OK, i know see that the issue is replacing the top facia, which is not an issue when leaving the std deck. Thanks heaps.
your call.
I only said part of the reason... :blush:
These cars may given a good bounce around on their journey to Oz, much more so than the domestic sea journey between the Japanese islands.. Surely that might make some contribution to a weak head drive finally collapsing.. I had been told that this was why the CD/DVD heads are parked on the audios as part of the global industry leaving the factory check list...
So are these Nissan/Bose units worse than any other brand? Was it a fundimental design flaw? As the other parts of the units, radio, tape (yes I did use it once I found the stuffed CD) external CD changers etc. seem to work quite well.
And as for pulling down the dash... It really isn't so hard, once you read through that stuff on the G35.. Also gives you a chance to correct the "tiptronic" shift direction when you have the centre console out. :yes:
Edited by nickcorr
so you follow now. its not that bad.
do you want me to send you a lead?. can have one there thurs morn :blush:
true on NEW units. these things are at least 6 yrs old (they swapped the decks in 2004 and again in 2005.) before you get them. given most of these are 2001-2003 versions they are well and truly on the way out. the laser alone is not meant to live past 5 yrs.
they are FULL of flaws. there are design flaws in the PSU section for one. I dare say thats why nissan changed them late 2003 and again in nov 04. 3 units and 3 different mechs. the middle unit runs the same mech as a PN2541 (350Z radio) and that one suffers flaws as well. (electrical- they changed the design a LOT in those so they do not self destruct.) the 3rd revison they appeared to fix the electrical issue in them and a minor mechanical change from what I can see.
correct. though the shifter is a matter of prefernce.
now that i know whats involved i can tell the boss what the go is, as its her car, but id say she will be keen.
i know the shifter works in reverse to most cars but i like it.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
