Hi guys...
I'm no expert with steering so I'm hoping you lot can help me with this awkward vibration/noise I seem to be getting through the steering wheel. I'll try and symptomise it the best i can for you:
- Can feel it through the steering wheel as a slight but constant vibration
- Similar in feel to driving on really rough road
- Not a wheel balance or allignment problem as I recently had new wheels fitted/balanced/alligned and the problem is still there
- I can feel it at both low speeds and high speeds, not as obvious as idle (perhaps influenced by RPM and therefore accessory related?)
- It is present in both straight line and turning so I don't think my tyres are scrubbing on anything
- Power steering fluid is full
- When I got the timing belt changed, the mechanic kindly wrote down that I had a noisy power steering pump
Could this be caused by camber at all? I'm feeling it's something in the steering system - leaning towards the power steering pump either resonating a bearing vibration through the power steering lines and to the rack (long shot?), or the pump isn't supplying fluid to the rack / blockage in the system somewhere.
Any ideas?
https://www.sau.com.au/forums/topic/312193-steering-vibrationnoise/
I had a smilar problem not too long ago.
My problem was with the front tyres being worn on the inside, the tyres also had scalloping - could have been caused by camber wear (my suspension is stock), stop/go traffic tends to wear front tyres faster.
- Check the toe-in/toe-out.
- Tie rods ends could have some play in them (worn out) - best replace them.
- Worn out shocks - small bumps will tend to deflect wheels much more.
- Worn suspension/steering bushes.
Interesting. In answer to your suggestions - my tyres are brand new, my shocks (Tein SS coilovers) are less than a year old.
Will check the toe...bushes may be worn as I haven't had them replaced and they are probably originals. Did have plans to put polyurethane throughout so I might go ahead with that and kill everything with one stone. I was thinking tie-rods...just didn't know whether it would resonate vibration or not.
Thanks :banana:
P.S. car is R33 GTS-T.
i have had steering wheel vibration issues in cars before but i don't think they will apply here because of the fact that the cars were fwd, but may still be something to consider. the first sign is if the vibration gets worse when accelerating. if so, check the engine mounts. my last magna used to get a major steering vibration happening when accelerating (even just pushing the accelerator down about 20% more than when cruising) at above 90kmh. even just trying to stay at a constant speed an a bit of a hill would do it. this was caused by a shagged engine mount.
The only reason I don't think it's a balance problem, is (unless we have a big coincidence) that the problem was there before I put the new wheels on and still there after. Now this vibration is a very small thing...and I only notice it because I'm pedantic about my car running perfectly. It's not a visual shaking of the wheel or anything, it's almost similar to rough bitumen road noise in terms of sound and feel. If you've ever driven a car with low power steering fluid, that is similar to what it is like. More than likely something vibrating from the engine bay, be it a worn engine mount or power steering pump, but I won't be ruling out suspension and wheel bearings.
I'll try swapping the wheels too and see if I notice any difference.
Actually, I noticed tonight that I had a similar vibration. Only really noticeable at highway speed, but you almost have to feel for it. Then I recalled being told a while ago that I had a bit of wear in the rack ends. Might want to check that possibility out.
Changing front wheel bearings as I type this so hopefully this solves the problem. If not I'm gonna jump up and down angrily :)
Next step after that is steering tie rods and/or lower ball joints. After that I'll change power steering pump and rack.
My biggest problem is that visually everything looks okay, and shake/clamp tests haven't revealed much either...leading me to believe it might be rack related. It just feels like a rolling issue though, hence the wheel bearing assumption.
What annoys me is how much road feedback I can feel through my steering wheel. Or it could be engine/pump related vibrations that I'm mistaking for road feedback because it's not always consistent with the road.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
