ok ive got the car running after i installed a highflow turbo, JJR split dump/front pipe modified into a screamer, and wrapped the top half of the dump pipe with exhaust wrap.
started it up and its quite loud, exhaust is flowing out of the wastegate at idle, is this only while its cold? or is this the ghey thing about internally gated screamers?
what could be causing the black smoke as i rev the engine? would it be the standard ECU riching it up coz of the highflow? or anything to do with the dump?
also after running for about 2 mins i noticed the turbo/dump pipe area started to smoke, is this just becuase the exhaust wrap is new?
cheers
jimmy
Unless the wastegate area is perfectly sealed from the exhaust I imagine you will get exhaust flow from 'screamer' all the time.
Black smoke I would put down to standard ECU running overly rich as you mention.
& yes exhaust wrap will smoke for a long time. Takes ages to burn off & generally stinks too!
idle rich is mainly on O2 sensor. Plug it in to a Diagnostic computer and see if that shows lean rich lean rich lean rich .... it doesn't then O2 sensor needs to be replaced.
What is this internally gated screamer? did you chop a section off it for the external gate sound? One of my friend tried it. Car just sounds like a permanent exhaust leak. Didn’t work as expected.
Also you must adjust the stock actuator flange to ensure waste gate is shut. We adjust it free of charge if that was sent in with the turbo. Information regarding "how to" is on my 30 pages thread.
the actuator was bolted onto the turbo when i sent it in, ill have a read 2mro.
taken it for a drive and the bloody thing is overheating, got to 3/4 on the gauge then i came home and turned it off. the 1st drive i accidently left the coolant bleeding screw loose so i thought that was the prob, got home tightened it up let it cool off, went for another drive and the temp went to 3/4 again came home and theres fark all coolant in the system. maybe a leak from one of the water lines to the turbo? i had to reuse the old copper washers coz i couldnt source any, any ideas???????
In This case the actuator has been adjusted. No need to touch that.
If water is leaking through the cooper washers you will be able to visually see it. Get a pressure tester onto the radiator and see where the water is leaking from.
hav a feelin its coz i didnt bleed it properly so ill try that wen i get home.
also the car runs like crap, no power at all under 3000rpm then quickly makes boost to around 15psi and feels sluggish. this is probably coz of the standard ecu yeah?
Well few reasons. First of all turbo is bigger and heavier built with steel so you will notice some sort of lag. Should be getting full boost around 3500 mark. Drive it for 150KMs you will note the response of the turbo improves.
After a good tune with supporting mods, you will get around 250rwkws mark.
15psi on standard ECU = not good. Rich and retard for sure...why are you boosting it without getting it tuned? My only driving after bolting on a high flow turbo would be to my tuner unless you have the wastegate set to standard boost.
ok time for an update, the cooling issue looks to be gone, i bled the system properly this time.
car is running ALOT better now with the boost controller disconnected and it doesnt feel laggy anymore (ecu must of taken out timing and maybe hitting r&r)
but now ive ran into another problem.....overboosting. so i put my foot down boost starts to build around 3000rpm, boost builds quickly to 9psi then about a second later it climbs quickly to 17ish psi then i back off. im guessing this is the split dump :blink: i dont get it but! if the JJR split dump are THAT bad how does he sell so bloody many of them, and i did die grind the inside of the wastegate section on the dump pipe where its fouling.
what checks can i make from here? blowing compressed air into the wastegate??
EDIT: and also SOMETIMES the car stalls after i bip the throttle like its running an atmo bov, i have put the standard one back on but since ive got a different intake pipe its custom return piping, would a slight restriction in the bov return hosing cause it to do this?
Edited by jimmys-33T
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
