hi all questions about adjustable cam gears. I know you get what you pay for in the end but is it nessary to pay the $300 per gear for say hks, tomei ect is there cheaper alternatives that you guys havent had any problems with. I just dont see the point in spending the money on the big brand names where there are as good for cheaper. Now i dont like the idea of only 3 small allan key bolts holding the adjustment on the cam gears so i am after anything really with the 5 locking bolts chears
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/
For Peace of Mind...I always use a well known/Proven Brand...Trust, Tomei, Toda, HKS there all around the $450-500mark for a set (IN/EX)
As you should know If they stuff up so does your head etc etc....
TODA is always my choice :blink:
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/#findComment-5148180
thanks for the info guys yes i understand brands are proven but saying that if the cheaper ones are made from quality materials and lock tight is used on the securing bolts i cant see a problem with that can anyone else ? and i am also very much aware of what will happen if shit goes wrong with them hense me asking before doing
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/#findComment-5148193
sorry I have to disagree with that - slipping adjustable gear would not move far enough for pistons to hit valves, they only allow a few degrees, not enough to hit.
I know of 2 people that it has happened to running China Crap Gears...
Although Might have other factors such as belt jumping a tooth, but on inspection the gears slipped a fair amount, And yes they were installed by a Reputable Workshop.
But i am sure alot of people are running the cheaper gears without ever having a problem.
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/#findComment-5148219
yeah i am sure to there is no worries with me installing them i wasnt worried about that i was more worried about them coming lose and if the extra money was honsetly needed as i am not to experanced with the rb26's
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/#findComment-5148326
Duncan i bet your heart stopped...
Scott im sure jjr ones wont have a problem if there installed correctly. But if your trying to compare them to the jap brands.. They suck lol
lol aint that the truth! I've been running JJR on the race car for years with no issues (other than user error lol)
also have run the tomei ones and found no difference.
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/#findComment-5148341
actually....one thing.
I don't trust the degree markings on *any* cam gear, china or not.
ie don't read the internet and just set them to exhaust +4, intake -2 or whatever.
you *must* dial them in for your exact setup. so expect to spend some dyno time trying different settings otherwise you are wasting your money
https://www.sau.com.au/forums/topic/313382-cam-gear-brands/#findComment-5148346
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
