Hi everyone ,
I was thinking of using a percision 7168 on a built rb25 with auto behind it
Was thinking to use a ported h front cover
What size rear housing should I use (.68 .81)
Has anyone used one of these, what sort of power would I get (18-20 psi for street ,28-35 psi for drags)
Was thinking about e85 but not shore. Closest e85 is about an hour away
Need to decide on turbo to built custom manifold
Any info / advise would be very helpful
Thanks everyone
Hi everyone ,
Thanks everyone
Argh people really need to mention power targets when saying they want a turbo suggestion. What are your targets? If you are going for 35psi for drags I am assuming a lot, and you're going to need to run E85/C16/Q16/something which can handle the associated pressure.
Please clarify :)
I was thinking about 350 kw for street & for the drags, I'll have to boost the hell out of it & hope for the best
I want to get at least a high to mid 10 in street trim, & for race at least a mid to low 9
I thought I might have to run e85. It will make it easier for racing (load up race tune, put the slicks on & hold on)
Not sure how well a RB25 would go with an auto and that large a turbo - you won't be getting full boost until around 6000rpm at a guess, and mid-ish 10s with 350kw would be pretty damn good going too, depending on the chassis.
If you are split between E85 and petrol for practicality, just go an ECU (and tuner :/) which can handle flex fuel tuning. Are you specifically after a Precision turbo? FP have turbos which are a tad insane for sale at the moment which would be pretty mean for aiming for low 9s - again depending on overall setup: http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFPSUPER94&Category_Code=Turbo-FP
Can be attached to a T3 manifold and make pretty much all of the power, and while it would be hardly a street turbo it will provide a huge amount of power for the spool and is very very cheap (at the moment) for what it is. If you are looking for turbos of this hp area (1000hp+) then you're going to need some serious engine work - headwork inclusive if you hope to get everything out of a turbo of this size on 'up to' 35psi. Otherwise something like a Precision PT6466 or something of the sort wouldn't be a silly choice.
You can't run those times with 350rwkw.... If that's your power target then a 7xxx turbo is way too big
I think the faster times he was aiming for the unnamed "race" power level - 350kw was street mode.
Easily. But if it's hypothetically capable making that power on 20psi through an auto, I doubt it will flow enough to supply enough air to boost the same engine to 35psi :wacko:
For all intents and purposes he's asking for a turbo which would make 600rwkw (give or take) through a manual on E85 from what I can tell
Lol :D Yeah the wording was a bit hard to follow, I had to read the post a couple of times to get (what I think...) he meant.
Yeah making that power "nicely" I think would involve a nice modern 67mm turbo - so yeah, PT6766 and also the Super94 HTA I mentioned (which I have an ulterior motive of just wanting to see how mental they would be on an RB haha) ;)
What would be good for response and power to go for precision turbo?
Looking power terms 450 500hp
Not to laggy as mainly daily street driven.
Don't know much about single setups I've got 33 Gtr stock turbos looking for something different soonish.
Regards
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
