I know it's the shittest pic in the world but this should give you an idea of 6262 power potential. We ran it up at just under 2 bar (1.96 I believe) and it went 710rwhp (530rwkw) and 776Nm.
Stock bottom end RB26 with 1.2mm head gasket and Grex 9.1mm cams
Posted Image
What an effort, that stock bottom end must be loving you for it....
This seems a lot more than I would expect out of a 6262, was this on a hub dyno? Impressive effort either way.
Its in line with what I would have expected on a hubber - if not still a little shy of potential. I'd expect a cranked up 6262 to be able to crack 500rwkw on a rolling road, too.
That was just a single run, tuner actually wanted to go harder and felt there was still more left in it but standard head bolts didn't want to play ball. Have replaced with ARP2000 studs this morning.
It trapped at 135mph with around 640hp on the same dyno so would expect around 140mph now
Given that I've seen 491kW out of a plain jane GT35 on an SR and backed up with 147mph in a full weight 180SX, I would expect a 6262 to push over 500rwkW. I don't know how much over 500 it would do, but I guess the 6262SP was the one that put Precision on the map with a couple of EVO's that were trapping over 150mph and one into the 8's, that was enough to suck me right in back in 2008! :)
By the way I have a 6466 sitting here unopened in the box with a .84 T4 divided housing, it's been sitting here while I contemplated testing one on my own car but I'm going to pursue with what I have for now. PM me if interested.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
