Just spent a good few hours reading over and over this thread, the more I was reading the more I was getting gd up for my car to finish, okay for the last year and half I've been building my full house rb26 in my r32 Gtr
Specs are-
Bottom end-
JE Forged pistons
Manley con rods
Arp head/main studs
Cometic metal head gasket
Tomei oversized oil pump
Jun oil collar attached to my crank
Black full honed, blue printed etc
Acl bearings
Tomei oil restrictor
Ross harmonic balancer
Racepace extended 9l sump
Head-
Tomei 270deg 10.80mm lift Procams
Tomei type c valve springs
Tomei solid lifters
Tomei valve guides
Nitto head oil return
N1 water pump
Nismo thermostat/housing
Head all freshened up and machined to use aftermarket gear
Fuel setup -
Bosch 2000cc injectors
Pro flow twin entry fuel rail
5l surge tank
2x bosch 044 fuel pumps with a sard 280 internal pump
Turbo setup-
Precision 6466 DBB t4 twin scroll .84 purchased from gas motor sports
Custom crg twin scroll exhaust manifold
Precision 46mm external waste gate
Gearbox-
5 speed os giken gearset
Jim berry full Monty clutch
Have heaps of other bits and peices that I havnt mentioned but engine should be Goinf back in next week and keen to see what it makes on the dyno after run in tune, car will be running e85 all the time, will keep you guys updated but hoping for 500+kW
Edited by gdzlar1
  • Like 1
I've already purchased it man and got it right beside me lol, I honestly got .84 because either way the 6466 makes power but I would like the response aswell at the same
Time
Sorry forgot to mention it's got the t4 housing aswell
Exact same 6466 I put on my 25/30. Mines not really overly laggy, I couldn't imagine what the larger rear would be like though
That's insane pj 630kw is serious power lol, Anthony at mattouk said I should be able to grab anywhere from 500-550kw with this setup so let's see how we go, I was told by joe at gas motorsports this turbos wil do
It with ease I was Goinf the 1.00 ar but I want some response as it's a t4 so .84 was good for me I think
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
