As in topic wanting to see what jap exhusts you guys are running for r33 that are relatively quiet and I dont mean quiet as in stock but not ridicoulously loud so prob up to 95db as I dont want to go purchase one then to find its pretty much the same level as the one I got now. epas are on the rise these days and cant be bothered going back to stock all the time
Yeah I was looking at the trust since people are saying the kakimoto and stuff is pretty much like stock, how do you find the trust quiet enough to not get as much attention?
Have the Trust PEII & recon you would like it. Nice on idle, definitely not like stock but not stupidly loud...
Then as you really start to rev it up she goes wild! From what I have heard one of the more sedate jap exhausts
I've got a 3" Blitz Nur exhaust. I won't recommend it for your purposes. Has a fair bit of low rpm noise. I love it on full noise but have always considered changing for something with a little bit less noise when daudling around.
Luke
yeah might give it a go, I love the loudness of my exhust at the moment and the drone donest bother me just cbf coppin epa and having to take turbos ecus injectors etc
i have a 3.5 bee-r cat back, and it is loud (came with the car when i bought it). drone heaps. dont get it even look into it. i want to downsize or switch exhuast to something that produces a more RB burble.
you are from melb i see. i'd be happy to give you a ride if we happen to be at a meet sometime. although there are a lot of guys running the trust catback so you wouldnt have too much trouble finding a car to listen to
Ive got a 3" stainless X-Force exhaust with the bellmouth front pipe and its really good.
Gives really good results and sounds good, in no way too loud. im very tempted to put a decat pipe in actually give it a bit more grunt.
And yes im aware its not a Jap exhaust but still worth checking out, can hear the turbo spooling waaaay more now too sounds good as.
Edited by Rav3nNZ
i had a Jasma / 5 zigen 3.5" cat back & front pipe (with a bellmouth dump) on my previous 33, was very quiet down low but gave a nice scream in the higher rev range. Measured 93db @ 3500 rpm (from when i went through pits for inspection)
notice this with a lot of the Jasma exhausts that the cars come over with from Japan, they're not overly loud.
ive got a 3inch 'drift' exhaust, stainless steel from the dum, but running stock cat.. i personally think its loud, but cops dont notice my car so it must be qiuet.
i put in the silencer/resinator/restrictor in the tip of the canon when i want a qiuete drive.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
