Can someone cast some light as to why cops in Perth have nothing better to do than pull over performance cars for the most piss weak reasons and continually harass the drivers of these cars for no apparent reason as well.
Long story short, was driving along in East Vic Park doing the speed limit and what do you know, a marked car goes past and instantly turns around to pull me over. Their excuse - my window tint was too dark, what a load of f**king bullshit!!
As I don't have to say anymore, they stickered my car.
I took it over the pits at Welshpool and as I expected they picked the shit out of it. Just some of the faults they reckon are -
1. Too low - need 100mm clearance, which it has but the exhaust can is a little lower by 15mm WTF?
2. No load rating stamped on the 255's on the rear
3. Front mount Intercooler installed and as a result I had to remove the front bumper support. The intercooler is like a structural member and much stronger than the piss weak piece of flat steel that it replaced.
4. No battery box for ventilation
If anyone knows of a mod or a bracket I can fit so I can keep my front mount Hybrid Intercooler would be great.
Ok enough whinging
If it has Tyres or Tits
Its gotta be FUN!!!
https://www.sau.com.au/forums/topic/313956-conniving-canary/
Im not suprised, my car got a yellow for only 1 reason - the lowest point on my car (my dump pipe) was 90mm off the ground, only 10mm off the legal limit
funny thing was, i gave way to him as he passed me at a round about and then later down the road, around 100m, he stopped at a bus top, waited for me to pass, and then sped up behind me, right up my ASS.. then sirens come on.. im thinking..... wat the f**k man, ur kidding me.....
then hes like, this is a random license and breathaliser check, im like bullshit! (in my head ofcourse) acted all nice and polite, and he still slapped on a yellow
some cops really have their priorities ALL WRONG, anyone who challenges me on this should be shot!
I love these.
1:
The lowest point of your entire car and ALL of its equipment must be above 100mm.
This is not just to stop you from looking like a jack-ass, but its practacle.
2:
What cheap ass brand tyres are they ?
3:
Sorry buddy, but your intercooler is NOT stronger than your crash bar....your intercooler was probably installed for aesthetics and power you don't really need. The crash bar is there to save you, and your car. Again, don't do shit the cheap way - install the intercooler properly without cutting / shutting, and you have no drama's. If you need to cut the bbar to get it in there, the intercooler is too big. You don't need an intercooler too big to fit in there without structural modification.
4:
This is a simple ADR ... no comment.
Hmmmm, battery box? Now I have to admit, this one has me worried and a little confused. What does this actually mean in the context of having the battery in your boot? Mine is just sitting on a plastic dish (the one that came with the car) and clamped down (like it was when it came with the car). Is this stickerable?
R33's came with special batteries which allowed a tube to be plugged into the battery. This tube then went down thru a hole in boot and out under neath somewhere. This allowed the battery to ventilate. If you have changed your battery to an australian one, then i doubt it came with this modifcation on the battery.
There is also vents in the boot it self, bottom drivers side in the corner.. Take a look. Im sure that these are there due to the battery being in the boot.
I am running a jap spec battery so ive managed to keep that tubing. IF i was to go Australian type battery, i would just get a dry cell which doesnt need ventilaton as far as i am aware... =)
Edited by br3ndan
This.
why do tools like nic comment crap like that?
its like total cop talk
Legality says the car has to have 100mm clearance...which it does EXCEPT for the exhaust which is 15mm low. Sooooo it actually doesnt have 100mm clearance?
All tyres have to have load ratings on them.....his tyres do not.
To cut or modify a main structual part of the car is not allowed. Never has, never will....so why is it a problem that they picked that?
Not sure why you thinks its 'total cop talk'.
+1
Keep your car legal, it's not that hard.
15mm difference in height isn't even noticeable visually, but it is illegal. So just get your car raised 15mm, it will look exactly the same but will be legal. Not a big deal
If your car doesn't have 100mm clearance, you won't make it over the pits, literally.. there is a lip on the edge of the pit you have to clear. Stupidly low cars are silly anyway, best thing I ever did to the skyline (other than the 3L :)) was raise it up off its' balls. Handles better, better bump steer characteristics and no longer had to fear speed bumps.
Edited by bubba
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
