yep
i was driving on station st at boxhill and suddenly a cop car feel like pulling me over
so i stop and cooperated
he intro to me which cop shop he is from and what is he intending to do
just a breathe test and a liscense check
i dont drink so ofcoz i get 0 on the blowing stick(breathe test)
also he ask whether i am P plater and i say yes he ask whether my r33 is turbo i say yes and he said i better check with vic roads whether i can drive it(can i drive it?)
also i am on auto liscense so i am driving manual and i suppose to get a $105 fine...
he comes up to me and said: " is your car manual?"
i replied: " yes sir"
he said: "you know i can give you a fine on driving a manual car using auto liscense?"
i said: "yes sir, sorry sir"
he said: " if i give you a fine you may have to go to court as well"
i gave him this about-to-cry face, then he said: "um...hmmm...i donno what to do with you :D, but you cant drive this car from this point on, is any your friend can drive you home?"
i replied: " yes sir, i call my friend he lives in reservoir not far away."
he said: "ok then, becareful dont drive it coz i got ur record if you get caught again you are in big trouble"
i replied: "thanks sir!"
in the end i blowed a test and i received no fine but a warning on my liscense...how good is that?(must be my new haircut:D)
after all just a freaky nite but phew no fine no nothing happened....i think we should change our impression of the cops once again?
cheers:)
https://www.sau.com.au/forums/topic/31414-dam-nice/
  • Replies 55
I though Milk had started a thread about me when I read the title.
Hey Milk babe, you seem to attract attention from cops like a pig in an Arkansas brothel.
What would have happened if the cop wasn't so nice?
This is prolly gonna sound way harsh but had it occured to you to STOP DOING ILLEGAL STUFF?
I'd have thought what happened to you on the Great Ocean Rd cruise whould have scared you into legal compliance.
However, its up to you I spose, best of luck.
https://www.sau.com.au/forums/topic/31414-dam-nice/#findComment-634314
i hate hearing stories where police are nice to some people and not others it really pisses me off... People that do wrong all the time get off and those that have a once of thing get done... **** this shit! // rant over ;)
:werd:
No P plates + Power Restricted Vehicle + Manual on Auto Licence = VERY LUCKY
Had you had a penis you wouldve been stung for all three.
https://www.sau.com.au/forums/topic/31414-dam-nice/#findComment-634571
I remember seeing the coppers regularly down there when i went for lunch, etc pulling over skylines and the like regularly.
Funniest thing i saw was about 4 of them on bicycles waving a guy over in an R32 and defecting him. It was classic!
https://www.sau.com.au/forums/topic/31414-dam-nice/#findComment-634608
Guest RedLineGTR
thats just stupid....stop driving cars that your not meant to. Havent you learnt your lesson???? i'm sure that your more than able to drive a manual car but still if your keen on going to courts & fines and possibily getting your licence suspended??? if so then by all means.
Sorry for being critical but you've gotton out of alot of stuff in the past it will all catch up to u one day.
https://www.sau.com.au/forums/topic/31414-dam-nice/#findComment-635247
hm...sound like i am a devil to disobey laws here
that GOR incident is fixed and never gonna happen again so why bother pull it out?
i woulda go for a manual liscense if i dont have to work 7days...u dont believe how painful is that when it comes to be ur dad's shop u MUST look after..he doesnt care i drive a manuyal...then why should i
besides i am getting my international liscense tmr
so cheers:D
https://www.sau.com.au/forums/topic/31414-dam-nice/#findComment-635359
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
