  • Replies 48
Ye, mine is hand made, mufflers and all - super custom...
Either way forget the 3" people... he needs 3.5-4" given the power/turbo's he has.
Just go down to any reputable exhaust place near you... or whoever put your car together (im sure they know someone).
Tell them quite simply that you want:
- 3.5" or 4" exhaust
- Twin mufflers.
- Mufflers must be straight through, and must be as big as can possibly fit.
- No big cannon tips. If the rear muffler is 3.5", 3.5" tip etc.
You'll then have a much quieter exhaust than you do now - for about the same cost once you sell off the old exhaust.
There is no issue using restrictors, just control your right foot. It's really not that hard.
I drove around with a restrictor in for 8 months, never took the car past 50% throttle and 3500rpm.
- Twin mufflers.
thank you mate.
I know I can't control my foot, its hard for me sometime:) I think I better leave the silencer, I don't want make any damage.
do you know HKS SUPER TURBO MUFFLER? on HKS website they rate it 600hp. because I will keep small twin turbo setup forever, so no way pass 600hp.
if this catback not suit for me, I will find some good exhaust shop to made one.:P
The theory of "blocking your nose and see how hard you can blow" may not apply to an exhaust silencer :P
I ran one for like a year on my old S15 that was fairly modified, caned it senseless on a daily basis and it did no damage.
No your dilemma though. I got a 3" Nismo catback on mine, sooo quiet at lower revs, but may need to to go 3.5" and i still want quiet..
Hi everyone, i have full exhaust system, HKS dump and front pipe, trust 94mm catback, it is just too loud for everyday drive. my car made 340KW on 1.45bar, 280KW on 1bar, if I use silencer and low boost, drive it hard, will it damage the engine (maybe too much back pressure)?? i can hear the noise of air resistance when full boost (1bar) over 5k or 6k rpm.
I tried many exhaust shop, only 2 option to quiet my exhaust: 1 is change a small system, 2 is put the silencer in.
anyone give some idea??? i don't want damage the engine by using a silencer:(
thanks!
100% will damage it. if you drive it hard.
I understand it will damage if drive it very hard. but i mean foot down occasionally and on low boost which is about 14psi. not like drag race, or quick ran on mountain.
but anywhy i need a new system:)
My 2c, if your on a budget and cant replace exhaust at moment, get the apexi ecv but with 95mm internal diameter. its not the flange type, its the pipe one. My car makes over 600rwkw and the thing hasnt broken yet and it does make a difference. \
Over 600Rwkw?!!!!!! got any pics??? i wanna see this beast mate!
mate you have 600rwkw with a ecv? how big your pipe is?
can you go full throttle with ecv??
Edited by Nosure
have you guys actually tried to hit boost with a big turbocharger and a restricted exhaust?
The turbo wont even spool up when i had my exhaust restricted. Not sure about other cars though
yes mate, that what I thought. but my car is easy go up tp 14psi with a silencer. I never tried 20psi.
PS: my turbo is not that big:) only 2 baby t517z
Edited by Nosure
I just bought a apexi ecv 95mm pipe type.
hope this will work, and no resistance when its open.
:thumbsup:
thank god at last sombody not just talking shit on the internet! another clasic full of shit thread thanks lads! i agree with guilt toy by the way,unless its like a 1 inch exhaust you may meld somthing due to heat restriction!
Edited by aerofocker
maybe you got a external wastegate??
i think the actuator type's turbo will still spool up fine with restricted exhaust.
Edited by Nosure
If you put a silencer in, you are effectively making the exhaust what, 2" maybe less? (depending on outlet size).
If you then intend to even ATTEMPT to put your foot down you are going to do some severe overall damage without question.
That much backpressure with turbo's that flow that much is never going to end pretty
tell me about this severe overall damage? the car will be laggy and lose loads of power all over the range and retain heat in the general exhaust area fair enough.
I want to know what dammage you speak of?
You don't just get heat in the exhaust area, there will be excessive heat everywhere...
Try it and see, you can cook the motor. There will be heaps of extra heat in the head, warped head? blown head gaskets? valve issues?
Hell get it too hot and then you can also cause detonation and we all know what happens next.
Your turn.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
