  • Replies 41
Hi guys if you hear of any rb30 blocks or rb25de or rb25det heads for sale around town could you please let me know. Dont mind what level of assembly the block is as i will be sourcing my own pistons and rods, would be good if it has a crank, as for the head, the more assembled it is the better it is.
thanks
I've just started the same project haha
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5255905
Sweet, joint thread? Lol
Yeah mate. I am still trying to source the right block. I want the rb30 series 2 block of course. Had a few ridiculous offers from some wreckers. So basically we are both after an rb30 bottom end.
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256077
what were the wreckers after for them? whats your price range? ill see what i can do. is it just the block or with pistons, rods and crank? with head? or going 25?
I just want a complete rb30 s2 bottom end. I already have an Rb25det head on my car that I will use.
I got figures of 500-600 from some wreckers down Queanbeyan way.
I understand the going rate for such an engine should be not alot more than $100-150 based on what other people i know have paid for same engine type
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256236
SII has the holes for oil and water for turbo whereas SI have to be drilled. that is all.
i have heard prices as low a $50 for just a bare block. also if you can get a RB25 VCT head that would be best. RB26 head is a bit of work to fit. but is superior.
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256286
Yeah they go pretty cheap so I am not spending more than i have to on the stock motor. I will go all out on the upgrades. I just need a half decent motor to strip and go from there.
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256293
All RB30's out of R31's are Series 2, the just have holes for Oil/water as RB ONEVIA said. Only the VL had Series 1 RB30's.
I haven't seen any RB30 block that has been broken, ever.
And, I've still got a free RB30 bottom end. I have no idea what condition it is in, I just wanted to get rid of it so it's been sitting outside for a little while now.
Also, I haven't been looking but R31's/RB30's don't seem to be appearing forsale as commonly as they used too.
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256398
Outside ay, so pretty high chances that its rusted through.. :(
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256413
R31s started and finished a year before VLs so i dont understand why they all had SII blocks.
And also, with the s1 block, do they still have the flat surface where the threads usually are for the oil and water lines? Or are they from a completely different cast?
no idea on that. as far as i know the only difference are the holes for the turbo lines.
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5256444
That looks like the Lewis engines one, Go see Greg at pro engines, he can get cranks from melbourne, If not i have a crank that might be usable (note the might part)
A collar is a good idea as the 30 cranks only drive about 3mm of the pump gear and are prone the breaking the pumps,
Once again Greg can do that for around 350 fitted.
https://www.sau.com.au/forums/topic/314653-rb30det/page/2/#findComment-5257053
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
