old oil stank of petrol and had about a litre too much in, bear in mind i run twin pumps and 1000cc sards. wont take long at 8.0.1 afr to do that.was changed after afr set and prior to dyno run,car was never driven with the contaminated oil in the motor
sounds very bad to me.....fuel is a rubbish lubriant, almost as bad as coolant :D
but assuming you changed it, most of it was removed (no oil cooler?), and the problem was fixed that may not be it.....you don't have the oil that just came out of it?
  • Replies 76
right guys a further development. looks like we have looking in the wrong place. i now suspect something has gone through the engine.from where i am not sure. below are pictures of the head on number 5 the one that spun and number 5 piston crown,, i was running a 1mm headgasket. question is whatever caused these marks would it be enoug on a 1mm gasket to jam the piston enough to cause the crank to hit the bearing momentarily?.
i have stripped the turbo, nothing wrong there?. had a look in the exhaust there is some very small shiny magnetic fragments?. any idea where something that could do this had got in from..
The indentations look a lot like spark plug electrode mate.
I once left mine at a "reputable" tuner for dyno-ing after a forged rebuild and was not happy with the results, (less power everywhere with higher specs) and after lots of head scratching I pulled it out and found the pricks had melted plugs in it (dash 8's) and simply put new ones in it and gave it back to me.
yeah +1 for detonation.
would also explain why the bearing has gone on no5 too.
You would think it would be across the board but and evident in all cylinders. I suppose if no5 injector had issues there's a possibility.
What do the other cylinders looke like?
odd thought... but had you used a die grinder on or near your intercooler piping or anything that would have been open on the intake setup weather it be plenum, TB, ic piping, comp housing, intake pipe....
that pitting either looks like the result of ceramic bits off a sparkplug or metal filings from something not being cleaned properly after working on it..
hi Cartman, no mate if i ever do anything like that the cars is not in the garage, you can see some die grinding work on the head in the pics, i have over the weekend fully ported and polished the head. its away now for a light skim. now the piston tops are cleaned of they almost look as good as the day they went in..lol
all the valve guides in 1 piece? ive seen the inlets fracture and do similar damage.
that wont be the cause of the damage. its not detonation.
to only dammage 1 bearing its only oil contanimation. fron the look of it something has been sitting in the crank and got loosed. did you have the crank grubscrewed when it was first built?
of have you recently put on a oil cooler?
hi t04gtr
cars has always had a 19row oil cooler fitted.feedsin the top and drain at the bottom, the oil filter is mounted low on a remote so when you do and oil change the cooler empties too.
no grub screw mate, collar was sweated on and has never moved
no valve guides damaged at all.
i find it hard to believe det after looking at the pistons..
still wondering why?.
bernie
If you had lost an engine at 900klm you would feel the same way as Marko. The engine in question was a low revving item that was never put under stress...N1 went bang.
GTRNUR...correct...the mains are all shiny from eating rod bearing material.
So what kind of revs was it pulling and under what circumstances did it go bang? Drag/circuit?
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
