Ana Here guys.
trying to find a pre fab turbo back 3inch exhaust for my 2003 m35 stag, any help would b great
thanks guys and girls
All the pref fabed ones are out of Japan. The Legalis is one of the more popular ones around.
Mine is a 3 inch from the turbo back with a 3 inch dump pipe which flows very well and is not too noisy. Mine was made to the car by Charleston Exhaust in Blacktown, Sydney. He does need the car for a day but it s avey good install that delivers performance but with out all the drone of some exhausts.
Cheers
Andy
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5163415
Cheers
Andy
Andy, can you confirm if Charleston ever developed a dump pipe? They were going to and they had Craig's stock dump to use as a basis for the mould but he needed the dump back before they did anything with it. I don't know if it ever got back there, if not I might have to get hold of one because I would like to see what he could come up with :down:
I'll be getting the turbo back treatment there also once I get some major stuff out of the way first, have to get myself a job again before I start thinking about it.
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5163921
I have not seen what he developed but he fitted a 3 inch dump pipe to Danny's car when he did the exhaust. I don't know that he can make them up without the car for a day.
Cheers
Andy
Thanks mate, I will call in and get the low down sometime this week. I was going to pop in and say howdy to him the other day but there was a bit of traffic on sunnyholt road and I had an annoying kid in the back :devil:
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5164066
I was going to use Charlestone Exhaust over a year ago but at that time the flange profile was not available and the car was going to be stored with Bruce for a few days while the stock flange was copied. At the time my wife couldn't do without the car so unfortunately it didn't happen.
Anyway, I ended up buying a stainless custom dump pipe off ebay and found out it was made by Westside Mufflers. After speaking to Brad about just fitting the dump I ended up getting him to make the rest stainless 3 inch exhaust too. It was a bit of an experiment and the quality of installation is excellent. Only problem is that the end result is noisy (see 'drone' above).
The car is going back in a for a resonator box to be installed which I think is what the Lagalis (cat back only?) comes with standard.
Would recommend either Charlestone or Westside if you go for a custom exhaust.
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5164068
Ive been considering the Kakimoto R cat back for the M35, but unfortunately I would really like to hear some feedback on this exhaust, as i dont want that annoying drone. I have driven a Legalis equiped exhaust on the M35 (and used to have one on my C34) however the M35 I drove with the legalis was alot slower than my stock M35 - but you couldnt even tell it had an aftermarket exhaust, very quiet indeed.
Ben.
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5164081
The Kakimoto R is a little bassier than the Legalis and is about as quiet (both 86db @ 3000rpm with stock dump & front pipe).
The Kaki is a little larger in diameter (80mm compared to the Fujitsubo's 76mm).
I guess it all comes down to the muffler appearance between these two.
If you want a single 115mm tip, go with the Kakimoto R
If you want dual 96mm tips, go with the Fujisubo Legalis
Also, out of suriosity, does anyone have the twin square tipped Nismo exhaust on their M35?
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5164494
nah. i've only got the sound control large oval tip exhaust, i also still suspect it's locked in silent mode :action-smiley-069: hence why my car sounds like a vacumm cleaner unless you really pick-up the revs. the switch under the steering wheel appears to do nothing when switched between silent and sport and vice versa. bloody compliancer's!
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5164840
Ive got stainless flanges here...
Ive jigged up off the original to make a few dumps if anyone is interested.
I will post some pics in a week or so when Ive made another one, I had to redesign the dump as Iamhe's one was too big to fit. Just waiting on the lower flanges to be laser cut.
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5165389
Ana Here guys.
I would have to give my money on Charleston Exhaust for a complete system.......been using them for about 20 years now and they have never let me down with any custom setup. Bruce will make up a bump on the spot for you if asked....just needs your car for the day though.
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5166403
would prefer some1 in newcastle
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5167532
would be nothing better than a road trip from blacktown back to newcastle with a brand new exhaust chirping away :woot:
ok
1. what sort of cost r we lookin at
2.who is going 2 meet up with us
3. are they open saturday's
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5170724
ok
1. Ring Bruce http://www.truelocal.com.au/business/charl...haust/blacktown
2. If I have the time I can meet.....If it's soon and you haven't fixed it already i'll have a look at the sound your complaining about in the front end!
3. Seems so but you will have to confirm it with Bruce.
Edited by Jetwreck
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5171643
alrite thanks for that tried callin 2day no answer when i get in contact with him ill let u know what we goin 2 do
did get a quote from the guy that did the exhaust on brendans rs4s lilford exhaust thornton $1250 3" mild steel turbo back does this sound like a good price??
https://www.sau.com.au/forums/topic/315014-m35-exhaust/#findComment-5174022
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
