ive bought a nistune board and an rb20 ecu to use in my r33 and ive got a frequency switch from jaycar to control the vct.
ive been told the range is around 1800rpm - 4700rpm. should i go straight off this or should i do dyno runs with and without the vct to get it exact?
from what ive read the vct solenoid has a constant ignition feed and a switched earth. so really all i have to do is run an earth to one side of the NO contact and run a wire to the vct solenoid from the other side of the NO contact on the switch and then adjust the switch so that it turns on and off at the desired rpm? and of course have a 12v ignition and earth going into the switch to give it power, and tap into the rpm signal and run that to the switch?
also when adjusting the the actual switch to turn on and off at the desired rpm can i be free revving the car in neutral?
i used a MSD RPM activated switch, it just adds a ground between s certain rpm range than than removes it after that point is reached, effectly turning on , than off the vct soleniod. the msd cost like 80 dollers and looks nice, it can also be used for nitrous and other things
i heard the msd ones were a couple of hundred bucks otherwise i would of got one of them.
crans just check that the battery is alrite 1st, even if u hook up a jumper pack or something then if its still not charging check the basic conections (main pos and neg from battery, and the connections on the starter and alternator) if thats all good then get someone to rev the engine while u got your meter on there if the voltage still isnt going up then its your alternator, most likely brushes or diodes
The answer is yes. Since you have gone to so much trouble you may as well get the ideal settings from the dyno. Of course you can set it near enough beforehand and adjust it when you get the opportunity on a dyno.
The frequency switch will only switch it on or off at a set rpm. it isn't a window switch like the msd unit.
You could get it to work that way by playing with the hysterisis but that would only work in one direction (either increase or decrease in frequency) which makes it useless becasue your switch point would have to be at 1100 or so which you just don't see in regular driving unless you stop.
Dave has it right. Just got mine working(not tuned 100% tho) if you are driving revs hit 1200 vct activates you give it some throttle revs climb past 4700 vct turns off you quickly tap the breaks and revs drp below 4700 it dosn't re activate. you have to let the revs drop below 1200 fo it to be able to activate again.
How much for the msd unit and where can i order from?
my home made unit was just tested looks promising just need to sort out a grounging issue which stops the tacho in the dash from working.
rpm counter is slightly off but that dosnt matter quick fix should be a capacitor on the rpm feed to filter out noise
you just set it so it switches the vct off at 4800 or so but it's on the rest of the time. Having it on at idle isn't ideal but doesn't hurt anything from what i've read, if anything it cleans up the idle if you have biggish cams as it reduces the overlap.
Thats how i'll be setting mine up anyway.
I would have liked to get a greddy mss which would have done it properly and is a compact nice looking unit but they are discontinued.
I used the Msd unit when i changed from auto to man and couldn't get the nvcs to work and u can't go wrong with this unit...
Simple to install and adjust to any rpm up to 10k if u wish
U don't want it on at idle bc it makes it idle like shit .... dont know how it will react with bidder cams tho
Ended up sellin it tho bc its difference was verrrrrrrrry minimal on my stock set up
http://cgi.ebay.com/ebaymotors/MSD-8969-DI...S-/300399015408
r u talkin about the jaycar unit?
let us know how it goes n if theres any probs,
nah i built and connected the jaycar unit and it useless it uses low high triggers not rpm window.
A friend is helping me build out own vtc controller using a amtel cpu
yeah, msd went up in price i got mine brand new from local dealer for 90 dealers delivered the next day heh. msd is simple though like 4 wires; pwr, grnd; rpm signal; and one that either adds or removes the ground to the item you wanted to use it on. its liek a gray wire if you want it to have power in the rpm range or a blue wire if you dont want it to have power in that rpm range, quick and easy
  • 3 weeks later...
Just received my MSD RPM window switch. Good looking little unit. Still working on my home made unit but really need the car running properly.
Just reading that it can only ground 2.5amps will i need a relay connected or is the vct load 2.5amps or under?
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
