  • Replies 136
HAHAHAHAH.. Nicely played! :cheers:
Well, fully rebuilt motor, bigger cams, twin Garrett 2871-r turbos, plus all your other supporting mods.
It was running super rich on the day. I'm still waiting on my boost controller to arrive before I go in for another touch up on the tuning
LOL now where's that link !!! :yes:
  • 4 months later...
Hi everyone,
It has been a fair while since I've posted up anything, so I might as well get one on, but before that, a short summary of what's been happening :P
Around about 2 months ago I was driving along the M4, and suddenly my blow off valve pipe had come off due to the pressure which then rooted all my plugs :P
Afterwards, I took it to my friends workshop where we had replaced the spark plugs. We checked the blow off valves and found out that the ones which came with the car had been ceased up so I changed them to twin HKS ones, with the intention of buying the plumb back piece and plumbing it back but it was a fairly big task, and one of the plumb back piece couldn't fit on the new SSQV3 series. I also had upgraded my hose clamps to some thick hardcore ones, and cleaned up the pipe hoses to prevent that from ever happening again.
My car then was running fine for the first 3 days or so, even better than before with the new blow off valves and plugs. All the sudden, the trouble came. It kept on backfiring whenever I would hit boost, and it was running rich as. Seeing as thought before I had a similar issue, all I did was gave it a boot to clear it up but it wasn't working at all this time. So I had taken it back to my friends workshop and thought to save myself some hard earned money I would attend to it when I had the time. During the next few weeks, with my friends aid and hes tools we've tested the car with hot and cold plugs, sent off the injectors to be tested, checked the fuel pressure regulator, coilpacks etc etc, with no luck at all. As soon as the car starts, it would misfire and burn out the plugs. (3 sets had to be sacrificed) After all that I didn't have much time due to a busy period at work so just left it sitting there until I had time to organise it to be taken somewhere else which had all the equipment, which was a good 2 weeks too.
Towing was organised and job booked in back at Hills Motorsports at Castle Hill where it had originally been worked on. They then carried out more tests to see what the problem was and it turned out to be the air flow metres and also the Apexi Power FC. It seems that the air flow metres were different to the ones they had installed before, and also the tune on the Power FC had resetted itself and it was running on a very old firmware which they said was very bizarre. Mark said he could fix the problem up, but would recommend me upgrading the PFC to the D-Jetro version and cut off the air flow metres completely if I wanted to spend the extra money. I then thought that I was already going to spend the money on a re-tune and all so I might as well go for the D-Jetro.
After that, there were problems with freight, and by the time that I had got the D-Jetro which was almost 2 weeks later, there was a ton of jobs sitting at Hills Motorsports which had set me back a little bit but the boys were on it straight away. After the wiring, installation of the map sensors, brand new set of plugs, oil change, the car was ready for a tune on the rollers. I was extremely anxious when it was getting set up, hoping that there wasn't any further problems. Besides an intercooler pipe blowing off, which then they had cleaned and had the hardcore heavy duty clamps installed it was ready for a proper tune and everything went off without a hitch :) So after a cold start tune this morning, they boys had the car washed and handed it over to me TODAY!!
So a huge thanks to Mark and the boys from Hills Motorsports and John from Autojoy in Clyde.
Thank you all for reading all that as well. I know, it wasn't short at all ;)
I'll also post up some horrible pics, and I shall upload some videos from the dyno a bit later.
cheers everyone,
Garland
Setting up:
On the Rollers:
Screen Print shot from video:
Awesome shot and awesome car.
And adding to what you were talking about before in the thread about buying the GF something to even it out when u spend money on the car, i got 5 years before she figured it out ;)
Videos are now up from the dyno tune.
This was the very first run of the day which blew off the intercooler piping as you can see with all the smoke near the end. My dumbest moment of the day was me standing behind the car with no ear muffs or goggles on, which had left me momentarily deaf and blind :D
http://www.youtube.com/watch?v=Qa3imyz6GgE
Another run:
http://www.youtube.com/watch?v=7XwgraA3hWM
One more run:
http://www.youtube.com/watch?v=IDPRM9LPSmY
I'll assume that in this one he was just testing out all the gears :D
http://www.youtube.com/watch?v=6_UoxPTH7_o
And this last one, just having a bit of fun revving the car with a bit of fireworks :)
http://www.youtube.com/watch?v=zrOXrSFraN0
Hope everyone enjoys them!
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
