  • Replies 157
:) aint got enough coin atm.. but ill be out to watch though. might take my camera out too.
full payment for the trackday is due May 31 so you have some time left.
no spectators for this one, but probably better photo opportunities at the next SAU trackday or at the next High Performance Driving course that i'm running in November (if you want to be the SAU photographer for that day).
just to confirm its an Advanced course, coz in the paper work u pm'd it keeps going on about the high performance course??
uh... the title of this thread is Advanced Driving Course.
if you read page 3 of the pdf, it states "This course will help you progress safely to a top level John Bowe Driving High Performance course or club track event"
perhaps you're misinterpreting "it is a requirement that participants have completed a defensive or advanced course prior to attending our High Performance course. This ‘Car Club Performance Drive Day’ meets & exceeds this experience requirement." ----- the statement refers to this Advanced Driving Course (June 21) being a prerequisite for later the High Performance course (November).
hope that this clears up any confusion.
Kim, I may be in a position where I've moved my skyline on and have another vehicle, is there any issue with me bringing a different car?
absolutely no problem at all with bringing a non-Skyline along to this as long as the car you have is roadworthy. people often have last minute changes as well all know that things break!
the list is looking pretty sparse at the moment:
* GoAhead (form sent)
* niksta (form sent)
* Sparkys (form sent)
x Normsta
x Cheddar
x JSTA33
? RBJETT
? SXY 33
? dark.sky
? ozyk
? Ripp3r (didn't u do this course last year?)
will be hard to justify offering this sort of driving course again next year if the overall interest is low... :down:
C'mon people, it will be good to do this. I know it's a fair whack of money but it'll be a good experience and you'll have a great time. Maybe some of the guys who did this course last year put a good word in here hey.
That's not good Kimmy :) I've messaged all those people like you've asked but haven't had many replies, not sure what's going on but hopefully they wake up and get in on it. C'mon guys, pull yer fingers out, this is a great day!!!
P.S. Do you know if my mates brother (Mark Benham) has sent his form in?
no, i don't know yet, but i will catch up with Dean from John Bowe Driving early next week to go over the list of participants and update the list accordingly.
whats the minimum needed to go ahead with this?
I would normally need a minimum of 20 drivers to make the event happen, but as we have booked Mallala out for the day, we are committed to running this and will have make up the numbers with other car clubs (Porsche Club of SA, WRX SA, FPV etc), so rest assured that we are still going ahead with the event.
Luke - thanks for the additional two.
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
