Hi guys, I need a bit of help troubleshooting something. my rb20 r32 hesitates unless i give it alot of throttle till the engine temp gauge hits half way mark. It literally stops hesitating as soon as it hits EXACTLY half way mark. And also the hesitation is always till the 2200 rpm mark, it goes away if i go over 2200 rpm and goes away completely as soon as the car reaches half way on the temp gauge...
After reading around, the likely suspects are temp sensor / fuel pump / CAT sensor / TPS, i just cant figure out which ones fit the criteria described above, anyone have any ideas? What should i replace first?
Cheers
Edited by agentx
https://www.sau.com.au/forums/topic/315196-hesitation-upto-2200-rpm/
um, the ECU when its running on cold maps has basic timing and isn't very aggressive
im not sure if you can define "hesistating" but you arent meant to trash it when its cold
under 80deg water temp the ECU will run under correction and it wont be as good as when its hot (at 80deg)
if how long before it gets to half way on your guage? 2-3 minutes? 30 minutes? an hour?
mine take about 5 minute to get from cold to around 70deg ish and then its fine
when its warming up i drive it normally (anything other than flooring it)
zzz my daily does this...every morning (sss pulsar) so freaking annoying...i've had a go at plugs, o2 sensor, filter, but apparently its just an sr thing so oh well
All of my mates Rb's are a bit sketchy when 1st started...but yeah after the warmup, tis all good.....and yeah how long does it take for your car to come up to temp?
thanks for all these responses guys! to answer a few questions, the car was performing perfectly till about a few months back (no major work done before this started happening). The hesitation isnt just the car underperforming due to the engine being cold (Ive worked with cars for quite some time now, this is definitely a fault). The problem takes around 10-12 minutes of driving to resolve and the gauge to come half way.
To describe the hesitation a bit further, if you constantly have the accelerator pressed with the same amount of force and the rpm keeps increasing, as soon as it hits 2200 rpm, it feels like the fuel supply has stopped and the exhaust note changes and it feels like someones let the accelerator go all of a sudden, and then if you give it some more gas ... it goes above that 2200 rpm spot and starts to accelerate again.
I mildly suspect my CAT is not in perfect condition (collapsed maybe?) Im getting that checked out in a week or so ... but i dont see how that can affect this at the same RPM and only till the car warms up?
I have changed plugs and bought brand new coil packs as well in the last 2 months. fuel filter has been changed.
fuel pump is another suspect you reckon?
Hi mate; i'll get another thermostat and test it out but the problem is the performance while cold, not really how long it takes to get to warm level ... it shouldn't just be cold start ... i know performance is slightly decreased when the engine is cold but this is a definite fault.
cheers
cheers
The performance decrease is due to the maps the ECU is using when below 65deg, it's not due to a cold engine/poor atomisation/etc.
My point about the thermostat is that it normally gets to operating temp. very quickly if driving so you wouldn't notice it for too long at all normally. But, IF your thermostat is sticking open then it's suddenly going to take a lot longer to get to operating temp. and as such you now have a lot more time to experience the cold start running.
Could be other things like dodgy connection on water temp sensor holding it in cold start for longer..
I know that when I built my 30, I snapped the RB20/26 water temp sensor so threw the RB25 one in there.. different resistance.. ECU thought it was in cold start all the time!
  • 1 month later...
Hi bubba, I am having troubles with idle and changed my temp sensor to one from a different NIssan. I know that it is a different colour to the one I had; what colour is the 20/26 one and what colour is the 25 one?
20/26 is yellow and 25 is brown
My car used to do this. But since the powerfc and splitfires were put in it has never done it again. Revs 100% fine when cold
Personally I'd rather a more agressive cold start to remind me not to hammer the car when cold, with the 3L it drives perfectly fine under 2000rpm on cold mornings, torque ftw :)
what can i say!!! why are you driving any rb when its cold??? let it warm up to at least the first line if not halfway by the sounds of things a blown headgasket or warped head is the way your going show your animal some respect turn it over a little build up some oil pressure fire it up give it a little flutter between 1 and 2 let it settle to a nice idle 10 mins later drive it.
all rbs run like dogs when they are cold actually most engines are not designed to be thrashed send me pm when you need new engine.
cheers
lagperformance
Bubba, mine is red. I kind of remember that when I got it the guy told me it was off a 300zx though my memory is a little hazy on this.
How do I know if my car is on cold start? Using a Consult cable I can see that the car is running at about 65 degrees when warm which is about the middle of my temp guage. Is there any other way to see of the car is running at cold start.
Thanks Ben.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
