hey guys was stripping my skyline but have no time anymore, decided to sell as a whole with whats left on it
engine near complete
body missing couple bits and pieces
interior almost compeltely stripped
for all info and pics etc. heres the ebay link i have put it up with a starting bid of $2500
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MESELX:I
cheers.
Edited by wAAA`
https://www.sau.com.au/forums/topic/315425-skyline-r32-gtst-melbourne/
Mate that's a lot to be asking for what is basically a shell with a common engine that you can buy for $500.
Not trying to be mean here but thats what I think if you're trying to get rid of it quick.
Russman: fair enough mate, i just thought it was a reasonable price, because i saw one shell on there with no engine or interior and also missing body parts selling for $1200 and another shell also with no engine with just rims for $1500
so i thought since mine still has the engine etc.. it would cost more than those
on topic: car has been relisted because i had somebody click "buy it now" with 0% feedback, his postal address was somewhere in Queensland and his user is now unregistered so i have no idea what his purpose was.. :ninja:
please only serious bids if anybody is interested.
thanks.
but those shell were probably undamaged.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
