I don't think that this belongs in the epa section of the vic forums, as i'm looking for opinions of ppls from past experiences.
I curious if my exhaust exceeds 90db. My set up in my R33- i'm running stock pipes from the turbo to cat- 3inch high flow cat (catsco)- 3inch turbo back exhaust (hakimoto [not sure on the spelling]).
Today I went and got the exhaust lifted to ensure that my car is legal ride height and they didn't have a db reader. I'm currently trying to tidy up any loose end to avoid and surprises further down the track, not really looking for fines either lol
If ppl have facts of this issue, i'm keen to hear your thoughts.
Thanks
https://www.sau.com.au/forums/topic/315694-legal-db-of-my-exhaust/
well i just cleared my EPA last week. 3.5" dump which i then bolted a stock cat back exhaust onto and my reading was 87db
seeing as you have changed from the cat back there is no way you will be at 90db or under.
Two mufflers should be alright. It's a qualitative measure so I'll wait to hear the vid but you should be right. I've got one muffler and a hotdog, it's alot louder than stock and the cop didn't say anything about my exhaust when I got pulled over for inspection.
Where did you get your exhaust lifted? and what part can get tucked up?
i'm pretty clueless to this stuff..but last time I was at my mechanics getting other stuff made legal, i asked him if he had a wheel to measure ride height. The entire car was clear except the middle exhaust bit that hangs down right under where you sit, it just clips his measuring tool a little and gets stuck. is there anything that can be done about that or should i be looking at suspension, not exhaust?
You can get any part lifted up as long as there's enough space between the pipe and the chassis. They'll just put a small mandrel bend in either side of the part that is too low. Alternatively, if you have coilovers you can just raise the car a quarter of an inch lol.
Cheers Birds, I'll get onto that.. any recommendations of a place to do it though.
Peter where'd you do yours? And where are you heading to get the DB sorted out and tested? shouldn't a mechanic or a wide number of places have these? if so, i wouldn't mind knowing my own reading. keep us updated on the outcome.
Quiet alr33x you hellaflush fool.
Any exhaust place will be able to do it for you mate. Ringwood performance exhaust were pretty good when I got mine done there.
lol @ "Legalis", funny as name.
Its doubtful that if its aftermarket exhust it will pass the stock r33 cat back is pretty borderline to legal ranging form like 86-90 and thats real quiet so doubtful any aftermarket would pass , can come close though
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
