hey,
I just took my car to hyperdrive, 2 get my springs install and i must say ken is a top dude :D and so is the whole team. the place is coming along nicly and i cant wait to see the dyno up and running.
Just like 2 say thanks 2 the team and ken :) and anyone need tuning, install of parts ect 2 take it to hyperdrive
https://www.sau.com.au/forums/topic/31600-just-took-my-car-2-hyperdrive/
Strich9ine, that is wat ken, said 2 me they will be abit hard.
on that note does anyone know if HKS Hipermax II
(Coilover Kits) ¥137,745
Full Set. Includes pillow ball upper mounts. Spring rate F: 69 N/mm (7 kgf/mm) R: 49 N/mm (5 kgf/mm).
is any good?
hello ppls, on my civc i got kings springs on, but wen i go over speed bumps i can hear the tyre hit the guard, i spoke to someone n he said it could be my shockies on how soft they are(so you may be able to change the settings?)....is this true and if so how can i get it fixed, or how much for a new set of shockies?
thanks
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
