gday guys
im looking at buying an r32 gts4, but its got a few small problems,
1. 3-4th syncro starting to go?
2.power steering pump is leaking?
3.tappets cover/gasket oil leak?
4. 18' by 8' i think tyres need replacing soon
just wondering if any one has had similar problems and if so know how much ($$?) and how hard it would be to fix these problems?
any input would be appreciated
also havn't owmed a skyline before and is any thing i should no about a r32 gts4 before buy ie good points bad points?
thx
Edited by tdbzs12
https://www.sau.com.au/forums/topic/316105-help-please/
to be honest they all sound minor and not surprising in a 20 year old car. All simple enough for a compentent mechanic to fix except #1....and pretty much every car will have that problem. you can mask it using redline shockproof gearbox oil, or if you prefer spend $3k reco-ing the box.
they are a great car with enourmous potential. just don't expect it to drive like a new one!
https://www.sau.com.au/forums/topic/316105-help-please/#findComment-5173966
yeah im not worried about the tappets oil leak just heard the power steering pump could be real pricey dunno if its true and yeah same with the 3-4 syncro thanks for your input mate
https://www.sau.com.au/forums/topic/316105-help-please/#findComment-5174746
where is the power steering leak? is it just out of around where the hoses meet the resevoiur, or is it at the actual pump? if it is the hoses at the top then that isn't a big issue and pretty much ever r32 and r33 skyline i have ever seen has it (unless the car has recently been degreased). rocker covers leaking is nearly as common.
https://www.sau.com.au/forums/topic/316105-help-please/#findComment-5175733
i paid 790 for my 18" ns2 nankangs (inc. wheel alignment), 9"s (went with 235) on the front and 10"s (went with 265) on the back. but i'd advise spending more than that, they're a bit of a challenge in the wet and i can barely keep up with kia's lol. fine in the dry and infinitely better than the old ones i had, where rain made me reconsider driving.
https://www.sau.com.au/forums/topic/316105-help-please/#findComment-5176385
