Theres a few big name aftermarket jobbies around, mines, HKS, Tomei and the price can vary a fair bit !
is there one particular brand that is considered better than any others ? (doesnt have to be jap)
it probably wouldnt be a problem on a low power car, but looking in the vicinity of 400-450rwhp every bit of flow would help (HKS GT-SS or 2860-9's)
cheers
https://www.sau.com.au/forums/topic/316283-best-dumpfront-pipes-for-a-26/
  • Replies 96
Cheers for reply :D I figured they'd be adequate for th power level. Same ad turbo manifolds. But in the chase for ultimate response would bigger be better ?
Also does ceramic coating and heat wrapping give enough benefit to bother with it ?
I made some good gains in response and power using the trust dump pipe kit.
Definatly ceramic coat the ex- housings, dumps and Y pipe. Also look at a heat shield on the front dump pipe, to keep as much heat away from the rear air intake.
Cheers
Justin
http://images.google.com.au/imgres?imgurl=...3OY3s7APwzenwCQ
^^^^^ hands down the best fullstop.
Best factory setup is the R34 gtr getup.
cheers mate ! looks like a nice piece of kit, any insight on weather an aftermarket ex mani is worth it ? again purely for MAX RESPONSE, i know the stock item is said to be adequate for fairly high power levels, but im chasing every bit of response i can
cf drive shaft
lightened flywheel
aluminium pulleys
anything i can think of to get nice early spool so even if mani/dumps dont get more KW its not an issue
As i said above - i swapped out dumps FROM aftermarket back to stock - there was no response difference to speak of.
just dumps or full front pipes ?
I know the dumps are cast pieces but if the stock front pipes on a 26(34 Vspec II if it makes a diff to zorst) looks anything like the pressed items on my old 32 (rb20) then id want to swap them pretty quick
R32 or R33, can't remember exactly :action-smiley-069: They aren't R34 items thats for sure.
280rwkw @ just over 1bar (i think around 15-16psi) on GT-SS's.
There is a another car i know of, exactly the same setup as mine, with a smaller exhaust - 330rwkw @ 20-22psi, factory dumps as well.
That's how we came to give it a go on my car, given this car was restricted to factory dumps for some sort of class racing i was told.
I'm yet to enquire if there are anymore setups that have since followed suit so i won't speculate.
If i ever get off my ass and finish off everything, i'll end up @ the same... I'm lazy :wub:
Nah not factory front pipes, aftermarket. JUST the Dumps im talking about.
The front pipes i have are 2.25" x2 (im pretty sure) into a merge with a 3.5" from there back.
cheers for the info, very knowledgeable as usual :action-smiley-069:
C.E.S here in Brisbane make a setup like the greddy setup, in stainless and mild steel, 3 inch or 3.5 inch, I run the 3.5 inch setup on my race car, I got them ceramic coated and they are surprisingly light for the size.
What kind of price are you looking at for those?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
