  • Replies 40
Also have:
Silver R32 GTR bonnet with small dint $300
Silver R32 GTR boot with spoiler and badge $320
R32 GTR front indicators Pair $130
hey mate can you send me pics of the bonnet an boot wing please
Hi
I would like to look at the bonnet and did the greddy turbo kit get picked up.
cheers
yes greddy kit was posted. i have to pick up the bonnet, will let u know when i have
will the rear calipers just bolt straight up to r34 gtr?
The front will bolt straight up but the rear will not. The rear is calipers only, no rear disk or brackets
is the clutch push or pull type? how much kw is it good for??
If you have a look at the ATS site http://www.a-t-s-usa.com/ats-products-R/c%...tch-table.shtml it states that the TWIN PLATE clutch with 1350kg pressure plate is rate at 800HP
All ATS clutches are PUSH type, but i have a OS Giken Pull to Push converter also forsale, this allows th clutch to be used in cars which use a pull type clutch (eg r33 gtr)
hey mate is the clutch push or pull? is it r33 gtr?
  • 1 month later...
  • 1 year later...
Still got lots of stuff left ta45 turbo kit is no ebay with lots of other bits for skyline
R32 Nissan Skyline GTR GTST A/C climate control unit disp...
AU $50.00
AU $55.00
bin_15x54.gif9d 20h
rb26dett rb26 ignitor igniter module GTR Skyline bnr32 bnr33 r32 r33
AU $90.00
AU $100.00
bin_15x54.gif9d 20h
Bee-R Fuel rail RB26dett skyline r32 r33 r34 GTR RB26
AU $89.00
AU $95.00
bin_15x54.gif9d 21h
TIMING BELT GATES Racing; SUIT NISSAN skyline RB20 RB25 R...
AU $110.00
AU $115.00
bin_15x54.gif9d 21h
JIC Adjustable Front caster rods R32 GTR bnr32
AU $240.00
AU $255.00
bin_15x54.gif9d 21h
GFB Stealth FX blow off valve to suit MY01+ WRX onwards
AU $180.00
AU $200.00
bin_15x54.gif9d 21h
HPI ENGINE TORQUE DAMPER NISSAN SKYLINE R33 R34 GTR RB26...
AU $180.00
AU $200.00
bin_15x54.gif9d 21h
Billet Steering Adaptor ALL NISSANS s13 s14 s15 r32 r33 r...
AU $40.00
AU $45.00
bin_15x54.gif9d 21h
Adjustable rear traction rods Suit S13 180SX R32 300zx
AU $80.00
AU $85.00
bin_15x54.gif9d 21h
AU $75.00
AU $80.00
bin_15x54.gif9d 22h
Nissan Skyline R32 door hinge Front right
AU $20.00
AU $25.00
bin_15x54.gif9d 22h
Stainless Steel Hose covers set RED UNIVERSAL
AU $45.00
AU $50.00
bin_15x54.gif9d 22h
VIAIR 400C AIR BAG COMPRESSOR, 4x4, MINITRUCK, HILUX, ROD...
AU $175.00
AU $180.00
bin_15x54.gif9d 22h
HKS VPC Suit RB26 GTR SYKLINE - REMOVER YOUR AFM AND RUN ...
AU $300.00
AU $350.00
bin_15x54.gif9d 22h
RB26 DETT head bolt set with washers GTR R32 R33 R34 rb26...
AU $50.00
AU $55.00
bin_15x54.gif9d 22h
ATS Twin Plate Carbon Clutch Suit GTR R32 R33 R34 bnr32 b...
AU $1,450.00
AU $1,550.00
bin_15x54.gif9d 23h
Os Giken Pull to Push clutch converter R33 R34 GTR Nissan...
AU $185.00
AU $195.00
bin_15x54.gif9d 23h
HKS TA45 Turbo Kit 600HP GTR RB26 R32 R33 R34 Nissan Skyl...
AU $1,350.00
AU $1,450.00
bin_15x54.gif9d 23h
Edited by GTR-31L
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
