We're going to be cruising up the thousand steps on Sunday at 10:30am via feet. Everybody is welcome :).
To get there you need to find this place-
Mt Dandenong Tourist Rd, VIC 3786, Australia
Link: <http://maps.google.com/maps?q=-37.888673,145.3176&num=1&sll=-37.883019,145.295404&sspn=0.035231,0.06403&ie=UTF8&ll=-37.891027,145.320604&spn=0.016104,0.026157&z=16>
We will meet under the large archway at the top of the car park.
Bring yourself, dress appropriately (there are 770 odd stairs which can get slippery if it has rained recently + a few kilometers at each end).
This event is restricted to good weather and I will update this thread if things aren't looking great.
Hope to see you there.
https://www.sau.com.au/forums/topic/317474-thousand-steps/
Picked it cause it's the day i'm going up :). Yes it's a day of rest.. except when monday is a public holiday right? Don't be weak sauce imo.
Anyways don't stress in any case.. i'll Probably keep posting dates and times to come along until I get the message, that i'm too slow, too ugly or that no one likes me :D.
https://www.sau.com.au/forums/topic/317474-thousand-steps/#findComment-5193696
