  • Replies 54
Posted Images
ill always take the piss out of the internet mechanics because i empathise with the person with the fault who has to trawl through all the endless shite posted to find their problem, afm should have been fault code 12 on the ecu iirc, when diagnosing a fault with these symptoms i would always check intercooler pipework first then interrogate the ecu for fault codes for the others eg afm cas ect ect,usually with the afm the car just wont go above 2krpm, i just wish i had more time to give the internet mecs more abuse
Edited by aerofocker
lol...but I will always take the piss out of you so called mechanical experts(x being the unknown factor spirt being a drip under pressure)....maybe endless shite to you mate but as you are not in the VQ25DET world I suggest you keep you smart arse comments to yourself....outside the Japanese language we are it for the VQ25DET!!!!....and unless you have something more constructive to add I suggest you shut it......we in M35 Stagea world don't suffer fools gladly....and I don't want to put you in the same boat as some others(e.g.nummers)
PS....for the VQ25DET(it's not a F#$King RB motor)....so error 12 to the VQ means P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1) to us...may not be that on a RB.....get my point buddy!
our errors below
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
Did you know that?....guess what?...it came off the Internet!!!!...from a so called internet mechanic.....are you that for behind the times that you have not realised that there are ECU's running cars now not carbi's ....bet you wouldn't find the VQ25DET in a service manual or PC at your workplace!
P.S. Did he not get the answer to the problem within 10 minutes and an offer of help from people with parts? Pretty f#$king good info is you ask me!!!!! give me another site with that!!!
Edited by Jetwreck
our errors below
Did you know that?....guess what?...it came off the Internet!!!!...from a so called internet mechanic.....are you that far behind the times that you have not realised that there are ECU's running cars now not carbi's ....bet you wouldn't find the VQ25DET in a service manual or PC at your workplace!
At least he didn't call you cockmaster... I say we bow down to our new son of rajab and master, Aerofocker!
Here's a challenge for you!......tell me and everybody else that has this motor something that we don't already know!!!!
outside the Japanese language we are it for the vq25det, congrats
maybe i touched a nerve ha ha
where exactly do you think i work by the way? and how do you get the impression i think these cars run on carbs? perhaps i should put more info for you in my personal profile?maybe my hourly rate?
good thing you wern't charging your hourly rate, if I remember correctly you got the diagnosis wrong.....
I guess people like me are lucky there's enough people on this forum willing to give their knowledge and time for free to help fellow stagea owners......
its quite reasonabel to suspect a boost leak,its the cheapest and easiest to find, as stated before im only interested in the guy getting his car sorted and giving plenty abust to those that are full of crap, enjoy your nm35s lads
its quite reasonabel to suspect a boost leak, its the cheapest and easiest to find, as stated before im only interested in the guy getting his car sorted and giving plenty abust to those that are full of crap, enjoy your nm35s lads
I see you abust yourself a lot then! :P
Edited by Jetwreck
I managed to get the bugger apart but it isnt just a couple of wires, there's a full surface mount board and processor tucked inside. No chance of repair, sorry Garett.
Be careful with your airflow sensors people.
Awww, does that mean no more pearls of wisdom? What a shame... Not.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
