hi gangs...
long story short, having problem putting the rubber joiner back on for the manifold inlet, what do i need to do?seems to hard to push it back down and slip it in at the other end. any other way i can connect it back?? rubber too stiff or hard..!! picture below will tell u what i meant..btw, i was trying to change spark plugs before i got stock to this problem..car been out of road for a week now..anyone from westside gimmi a hand for a can of VB or something??
cheers guys..
https://www.sau.com.au/forums/topic/317966-need-help/
have you connected all other end clamps? if so undo them a little to allow for some movement. It should just slot back in unless everything else is locked tight, with a bit of a wiggle a bit of lube and a few choice words.
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197815
i havent put the hose clamps back on yet..not enough gap or space to wiggle the other end...not even enough space to push it down and slot back in.!! really frustrating me now!! i got it out easy at the first place but putting it back in is an asS thing to do!!!
anymore trick to slot it back in guys??
Edited by myRB25DETT
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197825
what do you mean by not enough room to push it back down and slot it in, Try completley disconnecting the other end of the pipe so you have more movement to push it on then connect the other end when the throttle body end is on....where bouts are you?
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197868
sorry mate but the only way to get it on is to persevere at it and have plenty of patience. i always have trouble with my piping yet i eventually get it back on. Im missing a couple fingers off my main hand and i can do it.
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197883
well as u could see on the photo,i got the left side out, but the other end i couldnt, no way i could disconnect completely at the other end..pretty much dead end...i live in altona..next to altona beach or altona station...
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197938
There is no real "trick", just have to make it go in :blink:
Sometimes a tiny bit of oil around the inside edge can help
i know what u mean, but thats not even close to my case, my hose is not even facing evenly with the other end/inlet that you can just lube it and slot it back in...hose is slightly few m.m. above the inlet manifold and tried pushing it down to face the inlet and so i can just slip it thru but thats where the problem is, cant push it down far to face the inlet and then in...argggg
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197953
In your OTHER thread, it seemed to be all connected.
Oh well then, PM me your address and I'll come to you.
sorry to confuse u, but nah its not connected, and yeah thanks heaps for the offer....PMed u already for the add...let me know what i owe u!! :blink: cheers for that!!
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197969
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
