just did a suspension swap put in some tein super streets. unfortunately the car is jacked up like a mofo.
being a poor sucka atm, i didnt want to fork out $80 for a set of tein c spanners, so i got some generic c spanners from a bike shop. they kind of fit.
unfortunately I've quickly come to realise they werent good enough. my hand just kept slipping which resulted me punching my car countless times and bruised and bloody knuckles.
Anyways, i think i've done my fair share of swaring and punch. can anyone in sydney let me borrow some c spanners PLEAAAASSEEE! this is killin me.
i've tried the hammer and screwdriver trick too, its damaging the rings without much movement at all!
https://www.sau.com.au/forums/topic/318028-help-a-brother-out/
I don't have a set of c spanners around...but some suggestions:
Thoroughly clean the thread below the spring seat of any grit. Degreaser and a nylon brush should do the trick
Once it is clean you only need to move the bottom ring about 1/8 of a turn and it should spin freely on the thread. So the c spanner are only really needed for the initial loosening and then tightening again at the end. The top ring should turn freely down until it starts to lock onto the lower ring again.
If hammer and screwdriver won't dislodge it a c spanner wont be much good either :blush:
Brothels need all the help they can get too... But Help me first :blush:
thanks for the tips, I've been using wd40 on the threads. I'm able to dislodge the bottom ring and likenu sad it springs freely by hand. It's The top one I find the most issues with. Can't fkn move it at all, i think it's cos of the spilrng tension pushing down on the ring?
sorry....i assumed!
you should put a coil spring compressor on it first to take the tension off. For sure it will be a bastard of a job with the spring pushing on it!
about $20 at super cheap
spring compressor activated... it at least moves a little bit, but it is SO rediculously hard to turn. Do others have teins and can you tell me about ur experience? surely they couldnt have designed something so shit that you need spring compressors and still barely adjust!!! or am i doing something wrong
i was able to lower the rears, but the front is now killin my like cos there is hardly any space for compressors to go in... (and i dont think i lowered the rears enough =( F(@*@*#&@*!!!) have to go thru that shit again!
okay... adjustments done. some nice person let me use their Tein C spanners.
valuable lesson learned - dont be a fkn tightass when it comes to specialised tools!!!! just pay for it and it will save you hrs of stuffing around and possibly reduce injuries.
The End
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
