  • Replies 149
yes, Dean, wtf is going on? :D ... cmon we are all busting to know where and when :)
p.s. does anyone know what time is what at the ute muster? I was thinking of going and checking out the ferals (SAU company excluded John, Martin and Henry :( ). Anyone know the schedule?
Ok im sending out Pms on meeting spot now. Im still not entirely sure on where we can go cos i havent had a spare minute to go out and do the route i wanted to, so instead i will do somethin that everyone wants.
So suggestions here if u have any, otherwise i will work out somethin from now til sunday, or someone will suggest somethin then? Also does anyone wanna have a lunch break stop?
Cyas
People I pm'd:
midnightslider
legend
The Jester Of Oz
skidmark
nismostu
N/A®
hippy
Steve
4door_Sleeper
Jase
cell
paullys 32
P1E
TIMMMAYYY
Nightcrawler
VIPERGTSR01
If u r not here, that means u havent been sent a pm.
Cya all there :)
I notice some of the old schoolers like whatisname, Bugalugs, grepin and freebaggin are missing from the list.
It's UNAUSTRALIAN not to cruise on the Australia Day long weekend!!!
.... I guess I could kinda be an old schooler, as I turned up on the scene around the birth of SAU - not unlike yourself :)
Pity Rob sold his 33, Andy sold his 33GTR and Pawley has disappeared from the cruising scene :P .... so many memories ....
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
