Hi,
Has anyone experienced their VDC turning off while driving ?
This has happened a couple of times to me and will come back on when I stop and restart the car.
Flicking VDC switch doesn't turn it back on while driving.
On the way home tonight it happened again this time showing me the handbrake light aswell, the handbrake was not down, after about 20 min the handbrake light went but VDC remained off, I could tell by the way the car handled and the old yellow 'slip light' never came on. But after I stopped at the servo, VDC came back on and the old slip light was back.
I would really like to know whats going on but don't know who to ask, I have a hunch that it something to do with some kind of sensor problem.
https://www.sau.com.au/forums/topic/318371-vdc-turns-off-while-driving/
It is probably your brake fluid level. Sometimes it looks like it is full, but open it up and it could be near the minimum level, at which point your VDC will start turning off, and sometimes your ABS too.
Thanks alot guys my car is actually due for new brakes next week, Fingers crossed , otherwise I'll try the OBDII cable.
due for brakes???
they didn't do them at compliance?
should have been done. most of them that I witnessed coming through had the brakes and rotors done. some people sidestepped this and I dare say if you looked at your tyres they would bethe age of your car unless you changed them recently.
to answer your original question - get the brakes looked at first.
Mine most certainly weren't done at compliance (pads nor rotors), as my pads are pretty shagged and my rotors are rooted at 60,000km with massive lips. ALL of the V35s I had looked at for sale at dealers in Sydney (that were all fresh imports) had massively lipped rotors, which was at odds at the reported 25,000km or so that each supposedly had.
  • 4 weeks later...
Hi,
Hi Cruzen,
I'm experiencing the exact same thing, been checking the forum all night to see if there's a fix for this issue.
Did you find out what the problem was?
When I got my car back in Oct 08 55k on the clock it had new rubber but the front rotors were rooted as well with massive lips although the rears seemed ok, also my brake fluid was pretty low which would cause the brake warning light to come on during hard braking or if i was going down a super steep hill. Anyhow bought a new pair of slotted rotors for the front and had new pads fitted + new brake fluid and havent had the warning light come on
I had somthing similar happen to me the other day, lost tractions for a second taking off at the lights as there was a slight crest, nothing major just like a half a second loss of tractions any way long story shot, the "VDC off" light and the "Slip" light came on stayed on and wouldnt go away untill i l restarted the car, now iv checked the Break fluid its good, my tyers are near new 90ish tred, but brakes im not to sure on.. any sujestion to why this happens?
and for future refference what Break fluid should i get and where is a good place to pick it up, i live in brisvagus
Cheers.
Cheers.
Hi mate,
I just got Valvoline heavy duty dot 3 from Kmart, was on special at kmart only $5
Hi mate,
I though Dot 4 was standard in our cars and Dot 5 is what people flush the system with because its better. Didn't think that dot 3 would be a great idea.
Not sure. Maybe some of the other guys can verify if its a good idea using Dot 3.
The brake fluid resevoir I have in my car states to use dot 3 that's why I bought it..
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
