Recently my car has developed a drivetrain knock when 4wd engages. When torque goes to the front wheels I was getting a repetitive regular knock. Goes away when you reduce the throttle. It does not occur when 4wd is disabled. Am running the car in 2WD atm
Anyone had this problem before? Didn't find anything while searching. Had a look underneath the car as I did run over a branch on the road before the car started doing anything. Couldn't find any obvious damage. I have checked the attessa fluid, it is over maximum.
I do have a few error codes, 8, 9, 18, 18 is the ETS pressure switch.
Could something in the front diff or transfer case have let go?
https://www.sau.com.au/forums/topic/318448-transfer-case-front-diff-knock/
Not sure but i have a r33 GTS-4 and it will do this aswell. Mine doees it the second i release the acceletrator and ussual only ever in first or second.
Im going too be looking into mounts and bushings before anything like the shafts
These are the 4WD codes you are reciving from the attessa system
8 ABS actuator motor, motor relay or circuit
9 ABS actuator relay or circuit
18 ETS pressure switch or circuit
Edited by central coast person
  • 3 weeks later...
  Duncan said:
Hey Chris drop the front driveshaft out and see if that quietens it down. 4 bolts out she comes
thanks Will see if I can manage that myself when I get back, but I would of thought I'd have to cover up the holes if I was to take it out onto the road without a front driveshaft. (let me know if it's a stupid query as I haven't tried taking one out before)
Not exactly to confident on jacking the car onto 4 jack stands and then running it up to see how it goes. Sound dangerous to me.
  snozzle said:
if u take the shaft out wont it leak out of the transfer case on the gbox side? :S
You can buy toos from supercheaps and repco's that are about $10 and are a plug. You could make your own aswell i guess....
I found my problem mate, its my clutch plate hitting the clutch cover on harsh decel ........ Does it only happen to you when you decel in 1st and 2nd gear????
Well the 32 attessa system is different to the 33, my problem only happens when significant torque goes to the front wheels, ie medium to hard acceleration, and it literally feels like something is going to rip up the gearbox or go at any moment, it's a repetitive sound as well. I think I have the tools for this but would be interested to hear from anyone with a 32 who has done this.
the drivers side axle has popped out of the diff...just pop it back in with a long screwdriver or pry bar.
Hmm suppose I can check this as well, and pardon my ignorance, but I thought if something like that would happen the noise would be constant?
  • 3 months later...
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
