AHHHHHHHHHHH i think you will find, shell FTG (ferntree-gully) still sells V-power racing, almost certain (:S)
stopped using it 2 months ago, after i retuned baack to 98RON.
not 100% sure its still there, but they were the ONLY ones to have it when i needed it.
indeed because most of the "air" is not oxygen
Octain rating amongst other things is the oxygen content in fuel, the high the oxygen content the more complete the burn
the more complete the burn the more "perfect" the combustion
Theoretical all that will be given off should be h20
Of course this is not possable in real world what i was try to show was
I find it funny that a so called "better" higher quality fuel that will produce a more complete burn would be dis allowed to be used or sold because of tighter controlled emission regulations
unless of course its all a con
Ahhhhhhh, no.
First Octane rating is a number derived from a petrols ability to prevent knock. It has no direct correlation to the fuels formula. Once a fuel is tested it's knock prevention is compared to varying concotions of iso-octane and heptane then given a RON based on what % of iso-octane is required to mimik the fuels knock prevention ability.
Secondly, when you combine a hydroCARBON with oxygen you will get water AND a carbon derivitive, ie. Carbon Monoxide. Always. Without fail. Everytime. It's basic chemistry.
Um, if that's the case then they are breaking the law because V-Power Racing has not been made for nearly 3 years, and if they still have stock of it in their tanks (highly doubt it) it is going to be that old and very very bad quality fuel with all sorts of nasties in it. They will more than likely have Vpower 98 in there and if it's still selling for 5c per L more than normal Vpower they are false advertising as there is no more VPower Racing. You'll probably find it's the same price as normal VPower and that will be because thats what is being pumped out, they ,ay still have the signs up and the bowser cards in place saying Racing but I can assure you 99% that it's not Racing, the 1% is for the 3 year old stale left over (which again is unlikely because it would destroy your engine and would be taking up tank space that they could use for other fuels)
There's a slight difference in how they refine their fuels. You'll also notice, shells fuel is actually red and BP is actually blue/green. I might be speaking through my ARSE with the colours, but that's what I noticed on my fuel cap after a period of time...
There was some test done somewhere regarding the rating and additives they use, shell came up top.
I love Shell in my car but every bike I've ever owned friggin' hated it.
My NSR seized twice (both times were the only times I ever put Optimax in it...coincidence?), my XR would cough and splutter and also seized although I had run Optimax previously and my blade would cough and fart and carry on until about 7000rpm when it would clear it's throat and go like the clappers.
Conclusion?
Optimax -
Car = yes!
Bike = no!
I could have sworn the colour coding was there for a different reason.
I know leaded race fuels have a red colour and unleaded has blue or something along those lines
Back to back testing resulting in about 3-5 deg of timing retard required across the range from switching from BP ultimate to Shell V-power on my mates race car (SR20 putting out about 240rwkw about 20rwkw drop in power with Shell V-power).
He is now running ultra high octane race fuel now I think about 113ron and picked up another 40rwkw over BP ultimate different days different dynos different tuner.
fuels are actually clear, they put colouring in them for a safety reason, basically so you don't accidentally drink it lol! I'm pretty much sure the smell would put you off if you tried! unless you live in NT! Oh no I didn't lol
i use to not care when i first got car what i used. as in brand of petrol but after testing different ones out i cannot stand any shell petrol. makes any of my cars ive had run like absolute shit. only and ever use BP Ultimate 98. cars run awesome on it even had 1 car tuned to it as im happy with results
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
