I have Whiteline springs in my car. For some reason the front is lower than the back by around 15mm I think. It used to be 20mm or so but it settled a bit a few months after the install. It looks good but I'm not sure if it's deliberate or not. The height is meant to be 345 I think, but it's more like 335 on the back and 325 on the front.
https://www.sau.com.au/forums/topic/31860-whiteline-springs/#findComment-650843
Gee,
If that happens, then in a few months ground clearance will be lower than 10cm...
Does it need to be checked out? Maybe the mounting point or something else moves?
https://www.sau.com.au/forums/topic/31860-whiteline-springs/#findComment-650849
Hi Adzmax, Whiteline have their own engineer who designs their springs (and lots of other stuff) and they are made in a large factory. They sell lots of stuff to Repco, so maybe Repco sell Whiteline springs, not the other way around.
https://www.sau.com.au/forums/topic/31860-whiteline-springs/#findComment-656957
